Yes, Planned on it. Thats the first thing any repair manual I have ever read stated. Thanks for the help.
just to chime in....i had an air bag light for a while. It seemed random but i guess it was #3...It turned out to be the sensor bolts grounding on my prop rod. I put some electrical tape over them to check and sure enough the light went away and has been gone for many months now.
mine blinks but I was told it was because it needs a clock spring?
Get the Code so you dont waste the Money on a Clock Spring if it is not bad!!!!!!!!!!
Shaker,
sorry to bother you just once more on this....
I followed the link to the airbag diagnostic test series and it makes sense except for one thing. The checklist keeps referring to a LEFT front, CENTER front, and RIGHT front crash sensor circuit. I don't recall ever having a CENTER crash sensor on any of my stangs? My 92 has a left and right sensor, located behind the headlights. Is this all there should be, or am I missing something up there? Beyond that, I cannot find a reason for the code 41...open circuit in forward crash sensor circuit.
Any light you can shed is greatly appreciated.
Thanks,
Ken
Thanks,
Ken
There are Left, Right, and Center Crash Sensors. Pull the Black and Grey Connectors off the Diagnostic Monitor measure Pins 17, 18, and 19 to Ground for Resistance. If the Resistance is greater than 1220 Ohms then trace it to the Sensor, if the Resistance is below 1220 Ohms for all 3 Circuits then the Diagnostic Monitor is bad.
Ok, I will go get codes pulled first thanks!
Just count the Flashes!
OK, thanks. Then where, pray tell, is the center sensor mounted? I see no signs of one, nor a mounting location anywhere. I don't see any open bolt holes where one would have been mounted? It would sure help to know where this mystery center sensor should be located.
Thanks,
Ken
Thanks,
Ken
cjones
Thanks,
Ken
it should be center line of the engine, possibly behind the hood latch.
93 LX
cjones
5.0CRAZY
Maybe a dumb question... but mine flashes now too. 4 flashes....pause......then 4 flahses...pause and so on. So I assume that means its flashing a code 4? Or does that mean a code 44? Or what?
cjones
what year is your car??
90-91 code 4 - Potential short in Air Bag system
92 and up would be code 44 (4 flashes, one second pause then 4 flashes, three second pause) - right front crash sensor not mounted properly
5.0CRAZY
Its a 91..... I was just out again and this time I noticed its started doing 6 flashes-pause-six-pause. Then it started do 5-pause-5..... and I think I even counted a random 3 flash on its own. ( I was driving so I couldn't get a good look). Never did that before its been flashing 4's for the past couple weeks only. So I dunno
cjones
5 - forward crash sensor/ Ignition Circuit Short to ground
3 - loss of AirBag Circuit Deploy. Power &/or Backup Power Disconnect.
edit - forgot code 6 - Driver side Air Bag circuit inoperative
5 and 6 could be the clock spring in the steering column
- Replies
- 0
- Views
- 177
- Replies
- 11
- Views
- 619
Electrical
Air bag light
- Replies
- 2
- Views
- 1K
- Replies
- 0
- Views
- 1K
