  • 1994 - 1995 Specific Tech
Air Bag Module
  • Thread starter Thread starter islandreamer
  • Start date Start date Jun 10, 2006
I
islandreamer
  • Jun 10, 2006
I have (or had) a wrecked '94 GT and then bought a '95 six cylinder. I took everything from the '94 and put it into the '95. Yes every wire cluster, rear end, engine, trans, dashboard, ABS brakes and interior (black leather). I then went to use the air bag module but it was not the same. The one from the '95 has a part number F5ZF-14B215-BA. Do not have the one from the '94. The wiring connectors are different and have a different number of wires. The one clip on the '94 has 5 wires and the other clip has 10 wires while the '95 clips have 7 wires and 11 wires. The '94 has male clips while the '95 has female clips Everyone that I have talked to says the modules should be the same for '94 and '95 but this is clearly different. Has any one ran across this before? Can the '95 module be wired to accept the '94 wiring harness?
bimmertech
1,123
merriam, ks
Jun 10, 2006
  • Jun 10, 2006
do not cut and solder airbag wiring.
if you can change the wiring without cutting then do it. if you have to cut it then just roll bagless.
mytight95
2,605
Dothan,Al
Jun 10, 2006
  • Jun 10, 2006
i have one inthe shop, i will check the number on it, if it is what you need you are welcome to it.
jason
I
islandreamer
  • Jun 10, 2006
If I changed the wires it would be done at the connector by removing or replacing pins just like factory. Just do not know if the three wire can be removed without problems. Will be rolling bagless till that question can be answered. I have pictures attached showing the connectors on the '94 and the air bag module from the '95. If the one in your shop can take those connectors (male pins) I am absolutly interested. Thanks for your help
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
1987-1993 5.0 Distributor Shaft Length
  • AeroCoupe
  • Oct 13, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 16, 2024
89ripper
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
