1987-1993 5.0 Distributor Shaft Length
AeroCoupe
6,238
4,332
183
Claremore, OK
Does anyone have one out of a car and can measure from the top of the shaft where the rotor mounts to the bottom where the oil pump shaft goes? Curious if they are the same as a 94/95 unit. I have a 94/95 minus the cap, rotor and gear and I also have one from 87-93 car that is missing the shaft, electronics, and gear. If the 94/95 is the same length then I am going to start piecing a spare distributor together as I have the hall effect sensor and TFI modules new in boxes as well as a good used steel gear.
Anyhow, not in a rush but if someone has one out and can measure it that would be much appreciated.
Im surprised no one has answered you yet. I figured this info would be readily available. Do you need the exact measurements? Or just confirmation it would work?
Appreciate the links but I know the complete distributors will interchange. What I am wanting to do is use the shaft from the 94/95 distributor in a 87-93 housing.
