Air blowing??
  • Thread starter Thread starter my72mach1
  • Start date Start date Aug 18, 2007
my72mach1
36
  • Aug 18, 2007
I just finished installing a new intake on my 351C, edelbrock performer, and a new carb, also edelbrock perform. Got it to run today, but I hear air blowing from somewhere. It idles at about 900-1000, but hearing this air makes me think there is a problem somewhere. Any ideas? TIA.
Brian
R
ron67fb
1,117
SF Bay area, CA
Aug 18, 2007
  • Aug 18, 2007
Get a long rubber hose. One end goes against your ear, the other end you wave around the engine and pinpoint the noise.
Maybe it's the wind? Be more specific.
my72mach1
36
  • Aug 18, 2007
Here is a link to a quick video of the engine. Hopefully you can hear what I am talking about. Also, I tried to point out the throttle linkage, anyone know the easiest way to connect this? Modify the cable or is there a ball stud adapter available for the carb? Thanks again.
http://s214.photobucket.com/albums/cc104/bcholt23/?action=view&current=DSCN1705.flv
my72mach1
36
  • Aug 19, 2007
Update
Today I went out and cranked it up, car wouldn't stay running. Starts, then dies and sounds like it is starving for gas. If I hit the gas it will stay running, but as soon as I stop, it dies. I looked at the in line fule filter, there was some debris in it, thought it might just be clogged so I replaced it. Same thing, still dies. Now I am wondering if it is the ***e pump or could this be caused by a vacuum leak somewhere? Any thoughts? Thanks.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Aug 19, 2007
  • Aug 19, 2007
Maybe your intake didn't seal right and you have a vaccume leak. Get it running and spray carb cleaner around the sealing surfaces on the intake where it meets the block/heads and at the carb.
BlwnGazkit
153
Richmond, VA
Aug 19, 2007
  • Aug 19, 2007
The carb cleaner will stall the engine if you have a leak where it's sprayed.
It sounds like a vacuum leak to me, and the new symptoms describe a vacuum leak as well.
my72mach1
36
  • Aug 19, 2007
Thanks guys. I plan to get back to it this weekend and I'll let you know how it worked out. I think I have it narrowed to either clogged jets in the carb or a vacuum leak so I am going to check both.
Brian
G
Gud T.B. Blown
583
Aug 20, 2007
  • Aug 20, 2007
Do you have the correct intake for the heads? i.e, 2V heads with a 2V intake? A
4V intake on 2V heads will cause the problem described.
my72mach1
36
  • Aug 21, 2007
Interesting, I spoke to a guy at edelbrock and he said you can use their cleveland 4V intake on a 2V?
BlwnGazkit
153
Richmond, VA
Aug 21, 2007
#10
  • Aug 21, 2007
  • #10
Did you talk with a Tech or a Salesman?
my72mach1
36
#11
  • Aug 21, 2007
  • #11
Tech.
G
Gud T.B. Blown
583
Aug 22, 2007
#12
  • Aug 22, 2007
  • #12
my72mach1 said:
Tech.
I talked to a guy in tech about a intake 351C manifold heat riser b-off that I saw in their online catalog for some clarification about application. He was adamant that the piece didn't exist for the Cleveland manifold and I must be looking at an intake for a Windsor instead. Well I called Summit and ordered the part using the part number from Edelbrock. The point of this is just because they are tech doesn't necessarily mean they are correct.
I don't know how an intake made for 2V heads can also fit 4V heads because the intake ports are so much larger. Now if the tech guy was thinkng of the aluminum Edelbrock 4V heads, then yes, a 2V intake will work because the intake ports of the aluminum Edelbrock 4v are similiar to the 2v cast iron heads.
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Today at 7:51 AM
AlexM556
A
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
