air conditioner help
Either your system is empty or your low pressure cutout switch is bad. The easiest way to tell is to unplug you low pressure cutout switch. (it is located on the accumulator) and jump the terminals. The compressor should cut in. Do not leave it jumped for more than 15 seconds, but while it is jumped, see if you have cold air coming from the vents. If you do, than the switch is the likely the culprit. If you still don't have warm air than your A/C system is likely empty and will need to be recharged and the leak repaired.
Low pressure cutout switch shuts the compressor off when the freon level gets too low.
If it's low it leaked out. Replace all the o-rings with the green 134a o-rings, pull a vacuum on the system and charge with freon and oil
