  • SN95 4.6L Mustang Tech
Air Conditioning Not Working
  • Thread starter Thread starter Rau
  • Start date Start date Mar 19, 2012
R
Rau
  • Mar 19, 2012
I have a 2002 Gt and my air conditioning is not working. The compressor seems to be getting no power, because it will not start up. I checked the fuse and the fuse is fine. It's blowing air, but not cold at all. There is resistance in the knob when trying to turn it from hot to cold. Any suggestions on getting this to work?
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Mar 19, 2012
  • Mar 19, 2012
Just wondering which fuse you checked.
Are there any DTC codes? Are you aware that some DTC codes will disable the AC by design?
Confirm if there is +12 volts to the AC low pressure switch with the key (and AC) on.
R
Rau
  • Mar 19, 2012
I checked the A/C clutch defrost fuse 23 on the diagram, there aren't any dtc codes. It has the proper fuse 15A its blue. Could it be that there's no freon possibly? or there might be a leak in the line somewhere? because none of the line is cold at all, which im guessing means there is zero freon in the system at all due to a leak somewhere.
Bob2000GT
27
Halifax, NS
Mar 19, 2012
  • Mar 19, 2012
Most likely needs refrigerent. Same thing happened to mine when I purchased it. Do a search on troubleshooting the system and it will explain step by step how to use a jumper wire to check if the compressor and clutch are operating properly. If I can find the details I will pass them on. I added refrigerent and it was all good.
R
Rau
  • Mar 19, 2012
Thanks much
M
Mary brown
Banned
Feb 7, 2012
17
  • Mar 20, 2012
Think I may be in love with this
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
gkomo
2010 GT AC issue
  • 2010torchredgt
  • Jun 28, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Jun 29, 2026
2010torchredgt
