  • 1994 - 1995 Specific Tech
Air/Fuel + PSI
  • Thread starter Thread starter tjh566
  • Start date Start date Dec 5, 2006
T
tjh566
608
Northern Va
Dec 5, 2006
  • Dec 5, 2006
Whats the safe A/F Ratio for a supercharger, like the range, ive heard 11.5 was good, but if it were say 11 would that be ok just a little rich? or if it were 12 would it be ok just on the lean side? Trying to save my motor, just looking for an "Acceptable" range for the A/F. Thanks!
T
tjh566
608
Northern Va
Dec 6, 2006
  • Dec 6, 2006
tt................. I tried searching a little before this post but the search is hard to use from what ive tried doing, you get a billion threads none relating to what you want.
94CobraPace
907
Houston, Tx.
Dec 6, 2006
  • Dec 6, 2006
Around 11 is a good safe number. 12 is getting a little lean, especially if you are pushing over 10 psi.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Dec 6, 2006
  • Dec 6, 2006
While I was doing research to decide if I was gonna go NA or Forced, I spent a good bit of time on several power adder forums.
You would see an occasional dip go down to 10.5 and even as low as 10.0 from time to time in those boys dyno pulls.
Some of the time, they did not strive a whole lot to change it.
With forced induction, the additional fuel can help to cool the charge a bit.
Bottom line is you are correct about them running a good deal fatter than NA combos.
Grady
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
P
Air Fuel ratio bung location.
  • Praetorious
  • Feb 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
  • dan50
  • Jul 18, 2026
dan50
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
