air pump delete ?
  • Thread starter Thread starter twotone92
  • Start date Start date Aug 4, 2008
T
twotone92
marathon NY
Aug 4, 2008
  • Aug 4, 2008
i am in the process of cleaning up the engine bay and want to deleat the air pump.i want to just get a shorter belt does any one know what lenth belt i will need?i have underdrive pully's and the ford racing a/c delete kit that moves the power steering pump?
silvasnake
  • Aug 4, 2008
not sure what size but i had a similar prob i just took string and routed it around the pulleys and tied it in a knot like a belt carry that to a good autoparts store and they can measure it for you, i had to make two trips but i got a belt that fits great,, good luck
90topdown
138
Philadelphia, PA
Aug 5, 2008
  • Aug 5, 2008
Get a peice of string and wrap it around the pulleys. Tie a knot in it so the string is tight and then cut it away from the knot. Measure length of string. Take measurement to parts store and buy 3 belts. One belt that is the length you measured and then one the next size bigger and the next size smaller.
When you are done, take the 2 belts back that you didn't use.
04gtboy
83
  • Aug 5, 2008
Im using napa part# 060721 on mine but dont have the underdrive alt pulley on just the water pump and crank . No smog pump and same ps bracket . If its to long go a size smaller .
MarcMonteverde
66
S@c-ToWn
Aug 5, 2008
  • Aug 5, 2008
if ur taking off ur air pump, make sure u have an exhaust with no cats, because if u dont, the cats will be destroyed
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
5K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
F
89 GT smog delete belt?
  • fratzke
  • Feb 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 25, 2026
fratzke
F
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
