  • 1994 - 1995 Specific Tech
air pump noise help
  • Thread starter Thread starter SVT3183
  • Start date Start date Apr 24, 2007
SVT3183
180
S Jersey
Apr 24, 2007
  • Apr 24, 2007
my air pump is making a "wurrrr" type noise. when i rev it a bit it gets louder and i can hear it at what seems to be slightly slower rpm than the motor. more rpm's = louder noise. i'm not sure if i just never noticed this before or if something is wrong
S/CBlack95GT
2,018
Tampa Palms, FL
Apr 24, 2007
  • Apr 24, 2007
Mine has made a slight noise for years. I can barely hear it now because of the blower but it's still there. I will wait for it to become really loud before I replace it. It's nothing to worry about.
HISSIN50
34
129
Apr 24, 2007
  • Apr 24, 2007
Shaun's experience with them is the norm. They often are kinda noisy but otherwise innocuous.
The common spots that cause noise are the leaf bushings adjacent the vanes and the bakelite vanes themselves scoring the wall due to bearing issues. If a mainshaft bearing lets go, you'll start getting a higher pitched squeal.
I have pictures of what the pumps look like inside if you want to open it up. In my experience, once you open one and clean it out, you have to periodically open and lube them or they don't last too long. Also, prolonged periods of non-use can cause seizing issues.
Good luck.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Apr 24, 2007
  • Apr 24, 2007
Yeah mine sounded like a rod knock. I was freakin out!!! Then I found it with my stethoscope and was relieved. I just put a short belt and voila! No more problems.
Scott
SVT3183
180
S Jersey
Apr 25, 2007
  • Apr 25, 2007
Good luck.
i'm not planning on opening it if this isn't abnormal but i wouldn't mind seeing the pics out of curiousity if you feel like posting them
J
jmhkas
82
Bowling Green, KY
Apr 25, 2007
  • Apr 25, 2007
Smog delete works wonders
Methodical
1,192
11
59
Clinton, MD
Apr 25, 2007
  • Apr 25, 2007
Scott
What's the PN for the belt. Also, is there a thread here or a how to that shows how to delete this stuff. I've been considering deleting this and the EGR but am worried about how it affects emissions testing.
Thanks.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Apr 25, 2007
  • Apr 25, 2007
Thanks.
http://forums.stangnet.com/showthread.php?t=680486
I would run the 90.5 personally because the 90 is very tight, maybe too tight.
Scott
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Apr 25, 2007
  • Apr 25, 2007
As far as the EGR, I would leave it. It doesn't hurt your performance. But if you are insistent on removing it, you can. It will make your NoX (nitrogen oxides) output skyrocket, but if your state doesn't measure NoX like Arizona, then it's not a problem.
Scott
HISSIN50
34
129
Apr 26, 2007
#10
  • Apr 26, 2007
  • #10
I only have one pic uploaded right now (I think I have a few different pics on the other puter). This gives an idea though. You can see the two bakelite vanes exiting the drum and touching the inner wall. You can sometimes see scrape marks on the inner wall - that suggests mainshaft play or leaf bushing wear (not allowing the vanes to retract into the drum smoothly. Instead, the vanes hit the walls and drag - as the right vane in the picture is).
It's a real PITA to try and lube those little bearings that ride on the mainshaft. They're neat little roller bearings and are almost impossible to repack with grease.
Methodical
1,192
11
59
Clinton, MD
Apr 26, 2007
#11
  • Apr 26, 2007
  • #11
Scott
After reading your post I realized that I have under driven pullies. Would you happen to know if the belt would work on non stock pullies?
Thanks
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Apr 26, 2007
#12
  • Apr 26, 2007
  • #12
Thanks
I don't think it will work. If you do some searching on this site, you will find tons of threads about short belt info. Many reference which underdrives they are using.
Scott
Methodical
1,192
11
59
Clinton, MD
Apr 27, 2007
#13
  • Apr 27, 2007
  • #13
Scott
Thanks. Will do
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
R
94’ SN95 - Intermittent lope & bogging at moderate rpm
  • Red5.0ho
  • Nov 2, 2025
1994 - 1995 Specific Tech Nov 3, 2025
General karthief
90Gt squeal/chirp when hot
  • Bvoss59
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 14, 2025
General karthief
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
