Air sample tube
ummmm, can I assume that the reason you want to change the tube is because you are changing injectors? Im not a big fan of doing it that way, but some do get away with it with ok results. But the best way is to get a tune when you do changes like yours.
Ya I need a tune and have Moates QH, but my friend that is a tunehead is in the desert right now and I have to wait till he gets back... I have 36 lbs injectors in and thought I should have the right tube in , I looked and it still have the 19 lbs tube in ... I forgot to change it when I set it up so I am going to be installing the right tube for the injectors and just was wondering if I should reset the Comp after new tube install....
Yes. then rescue the tunehead from the dessert. Too much peyote will screw a person up forever.
