Air Sucking Sound from Intake
TurkeyLeg
on my '88 5.0, I have a sound that I describe as a fairly loud air sucking sounding when I give it some throttle(both in neutral and when its in gear). It sounds like its coming from the throttle body area, and its loud enough that I can hear it when I'm driving. It happens for a second right after I step on the throttle fast, then as it revs higher, it goes away. Also, when I'm cruising, if I give it just a little bit of gas, I can hear the sucking sound constantly. I have no vaccum leaks and I have lcleaned out the throttle body and entire intake. Its very annoying. Any help would be appreciated.
Generally the area you need to really clean on the EGR is the Pintle Valve and seat. They can get pretty clogged up with carbon deposits. I would check for good operation while the valve is off the car. This way you can see if it is sealing well enough.
That being said...i doubt thats your problem. I would double check all vac connections and all the connections at the intake tract and TB/EGR interface.
Its more of a whooshing sound like its sucking in a big gulp of air when you step on it. I'm running a cold air intake. I didn't even know that there is such a thing as an air silencer. Sounds like that is the issue, so I guess its pretty normal then to hear that whooshing sound??? Thanks for the responses, this thing is great.
