Air.
check if the standard vent is also stuck coming out of the defroster vent. If so, it's a simple fix. There's a small plastic vaccuum hose that runs along the firewall; it's broken or cracked.
:stupid: Yep, I'll send you a picture of it if you send me a better picture of the girl in your avatar. :D
yeah it was just that little hose.. thanks.
Its just Carmen Electra :hail2:
95mustang_gt said:
Could you send me a pic also,i have the same problem.thanks
attachment.php
attachment.php
Zero Signal said:
Check the vacuum tree on the driver side fender behind the strut tower.
Great call Zero! I had the same problem, went outside after reading this and the little guy was broken clear through. I fixed it immediately with some rubber vacuum tubing and zip ties to keep the rubber tube attached to the broken ends of the plastic vacuum tubing and the HVAC controls work as normal now. Thanks.
Tim
