Code 45 is the most common, I believe you are right. 45 has to do with some sort of ground issue. 90-93 Mustangs have 3 crash sensors. Right side, Left side, and Center. They are all mounted to the radiator support. Check the connections, and check all your grounds and fuses first. If nothing happens, you can have those old Mustangs scanned and cleared with cheap diagnostic equipment. There is also a module behind the radio or glove box , but if the vehicle has not been involved in a collision that is not the problem.
