Airbag warning light code. What does it mean?
QuickSilverShel
14
Hi all,
Yesterday, the airbag warning light started flashing on my 14,000 mile 93 5.0 GT. The light flashes 5 times, then a pause, then 1 flash. The cycle repeats over.
Can anybody help me with this?
Thanks
Hmm, every try the search function on the forum? :)
http://www.veryuseful.com/mustang/tech/airBag/airBag92.html
You have a code 51, that's not good in terms of easy debug.
You likely had codes before - something like a code for a bad sensor.
51 Diagnostic monitor internal thermal fuse open
Thankfully, the diagnostic monitors are cheap now. My guess is that you'll go through 1->3 of the monitors to hunt down the problem.
Note: You get two KEY TURN ONS before the internal fuse will blow. So, after the second, disconnect the battery, put your foot on brake pedal for 15 secs (to drain the caps in the EEC, radio, etc), wait 5 mins, connect battery, and you have get two KEY TURN ONS before the internal fuse will blow.
If you didn't get any codes before, it could be because of the "old electronics". Your best "bet" for best electronic life of a new diag monitor would be from a Northern Cold state, and from a car with low mileage (hopefully correlating to engine run time). Commercial-grade capacitors are the "most likely" to fail from age, use, temperature (use Google if you want to know more).
http://www.veryuseful.com/mustang/tech/airBag/airBag92.html#CODE51
Fault Code 51 - Diagnostic Monitor Internal Thermal Fuse - Open Due to Intermittent Short To Ground
Description: NOTE: The microprocessor inside the diagnostic monitor controls the internal thermal fuse. This fuse is not serviceable. The microprocessor will open the thermal fuse whenever a short is detected in the deployment circuits. The thermal fuse does NOT open because of excessive current flowing through it. DO NOT attempt to jumper out the thermal fuse with a circuit breaker or any other type of fuse.
NOTE: DO NOT install a new diagnostic monitor until the short has been located and corrected. If a short to ground has not been located and corrected, then the short to ground is intermittent and IS NOT PRESENT AT THIS TIME. If you install a new diagnostic monitor while there is an intermittent short in the system, the new diagnostic monitor will also open its thermal fuse and require repeated repairs.
Thankfully, the diagnostic monitors are cheap now. My guess is that you'll go through 1-3 of the monitors to hunt down the problem.
The debug of a code 51 gets involved quickly. If a new diag monitor doesn't show the initial/main cause (remember, you get only 1-2 key turn-ons), and the procedure on the web page isn't clear (really requires some electronic and DVM experience), then a dealer may be the best bet. My "100% pull it from my *ss guess" is ~~$500 (+/- $3,000 :)).
Good Luck!
Good Luck!
Thanks for the help on this. Sounds like I may be heading for a dealer because tracking down shorts in a car is not something I am proficient at. I'll give a dealer a call tomorrow and see if I can get this booked in. I hope your guess of $500 - $3000 is the correct guess. ;)
Thanks again for the advice.
QSS
IMHO, you can get an air-bag monitor for ~$30
http://car-part.com/ (or ebay).
For ebay, use the following search:
air bag mustang (92, 93)
So, it might be worth the try to put another one in, and see if it just works (unlikley), or if it throws out the code(s) for the real problem.
If there are codes, just disconnect the air bag monitor until you fix the problem.
Note, that without the air bag monitor, you will not have any air bags.
If you have it fixed, you want to go to a dealer, and not a local station. The dealer will have access to the diagrams. And, more importantly, mechanics who specialize in electrical/wiring problems.
The Fox air bag system is simple (on purpose). For an electrical specialist mechanic, it would be simple. The cost uncertainty is if a wire is bad or shorted. Hunting those done, and fixing them, can sometimes be very time consuming.
Good Luck!
I got my 93GT with only 16k on it, and from the day I bought it the light has been flashing. It not has just over 100k and yup, still flashing. I have not tried to fix it. We scanned it years ago and it come up with that code. I let it be.
Good Luck!
Well I took it to Gaudin Ford in Las Vegas yesterday. I told them that I have a code 51 coming up so they are going to have a look at it today. I'm still hoping for the $500 - $3000 estimate you threw out there in your first post :D
I'll let you all know what the damage is.
QSS
Wait, are you really going to spend $500-$3,000 on a flashing Air Bag light? I had the Air Bag Light flashing on my 94. Come to find out it was the clock spring (not what your thinking). It was pretty simple fix. Actually changed the steering wheel to a FR500.
The clock spring is the most common reason for an air bag system error.
BTW, clocksprings for a fox now go for ~$200->$300 on ebay :eek:, because they are hard to come by.
However, QuickSilverShel's car has a much different problem.
At the very least, QuickSilverShel's car will need a new diagnostic controller - the one in his car is no good since it blew it's internal non-replaceable "fuse". The diag controller will do that if it see's a "potential unsafe condition in the system". By doing that, it prevents the air bag from being deployed.
An example of a "potential unsafe condition in the system" is if an impact force sensor (or it's wire) is shorted. In that case, only the "safing sensor" (activates at ~7mph force) is preventing the air bag from deploying.
Many States/Counties require an SRS system (if the car has one) to work in order to pass the yearly/semi-yearly saftey inspection.
Also, for people that have families, people that depend on them, etc, a working SRS (i.e. air bag) is like insurance. There are tons of ******ed drivers on the roads, driving while texting, driving while drunk, driving while high, driving while talking, etc.
