I went with PA Racing's tubular k-member and A-arms. I was going to buy AJE but decided to go with PA. They are great, it fits perfect. I didn't do it to lighten the car nor for any other reason but looks. I didn't need the clearance or anything. I also bought the k-member and a-arms with spring perches so i could still retain my eiback pro-kit and kyb struts. Yes coil-overs are nice, but to be honest they aren't worth the money. I got suckered in and bought MM"s complete coil-over kit for my daily driver. When pulley into the drive way the rear coil-overs clatter because the rear end raises so high, i will never buy these for a street car again. NOTHING beats the stock style suspension in my opinion. MM's road still as crap as well, sure you can adjust ride height. But i never even bothered. It was just a pain because if you changed anything you always had to readjust it.
Just my .02
Edit: I will say MM is the best quality, but they are still over priced. And also the MM k-member screws up your front end specs. So then you front tire rubs the fender extensions, etc. Just a pain. Its not worth it in a street car. With that car i ended up going back to my stock K-member, tubular PA racing controls arms with spring perches and and a eiback pro-kit. Simple, cheap, and done right. No problems to this date.
