Alarm help
xbajbusx
58
hey i'm gone try to install alarm on 2000 mustang gt i need little help with the door lock because i always have problems gonecting them any help will be appriciated ,thank you
Car Alarm XR-7025 Remote Start with FM LCD 2-Way Pager
2006 DUAL REMOTE LCD PAGER ALARM
2-WAY FM REMOTE ENGINE START
TOP OF THE LINE FEATURES! BEST LOOKING REMOTES!
BRAND NEW IN FACTORY SEALED CARTON
ALARM IS THE ONE YOU HAVE BEEN LOOKING FOR, IT HAS ALL THE LATEST FEATURES INCLUDING REMOTE ENGINE START AND MUCH MORE.. THIS HAS THE BEST LOOKING REMOTES WE HAVE SEEN SO FAR IN AN FM 2-WAY LCD ALARM PACKAGE. THE DESIGN IS WELL THOUGH OUT AND WITH THIS NEW DIGITAL CODE TECHNOLOGY THERE IS NO WAY THIEVES ARE GETTING INTO YOUR RIDE!
FEATURES:
REAL TIME TWO-WAY FM TRANSMISSION
OPERATION VIA ONSCREEN REMOTE MENU
DYNAMIC PICTURE DISPLAY SYSTEM ON BOTH REMOTES
BUTTON LOCK FEATURE SO YOU CAN SLIP IT INTO YOUR POCKET OR PURSE
ALARM MUTE FUNCTION
AUTOMATIC CENTRAL DOOR LOCK CONTROL
EMERGENCY ALARM PANIC SYSTEM
DIGITAL ANTI ATTACK TECHNOLOGY
DUAL ILLUMINATED TWO WAY REMOTE CONTROLS
INTELLIGENT DOOR CONTROL
EMERGENCY DEACTIVATION FUNCTION
DOOR OPEN WARNING FUNCTION
TWO WAY REMOTE CONTROLLER LOW POWER WARNING
ADVANCED DIGITAL KEYLOG ENCRYTION TECHNOLOGY
AUTOMATIC ANTI THEFT SYSTEM
FALSE ALARM PREVENTION FUNCTION
REMOTES USE A STANDARD TRIPLE A BATTERY AND IT LASTS FOR MONTHS!
here it is
If this is your first install and you know a little bit about electronics, don't try it. As for the doors, use this information to determine what type of door locks you have: http://www.the12volt.com/doorlocks/doorlocks.asp
I do know that we have either a 3 wire negative or a 3 wire positive. I'll leave that up to you to find out.
A 3 wire negative will see ground during lock/unlock, but + 12V DC at rest.
A 3 wire positive will see + 12V DC during lock/unlock, but ground at rest.
Hope this helps you.
that site that topless posted is very useful. I used it a couple months ago when I put in my alarm. I think our locks are positive. You will need two releys for the locks. Get a Haynes maunal for your car if you don't have one it has all the wiring diagrams.
If I remember correctly, the installer of mine didn't need to use any relays for my door locks. :shrug:
