Alignment Specs
  • Thread starter Thread starter CHEAP CHARLEY
  • Start date Start date Aug 23, 2014
MY 65 HAS 67 SPINDLES. WHAT ALIGNMENT SPECS SHOULD I USE ?? 65 0R 67 ??
  • 65
    Votes: 0 0.0%
  • 67
    Votes: 0 0.0%
  • Total voters
  • Poll closed Aug 30, 2014.
C
CHEAP CHARLEY
NORTH CAROLINA
Aug 23, 2014
  • Aug 23, 2014
THE ALIGNMENT SHOP DID NOT KNOW.
rbohm
6,698
550
204
tucson,az
Aug 23, 2014
  • Aug 23, 2014
caster=+3.5
camber=-.5
toe in= 1/8"
for most street mustangs i usually recommend these settings.
barnett468
179
24
28
Aug 23, 2014
  • Aug 23, 2014
hello;
you need a new alignment shop. if most of the roads you drive on have a crown in the center, than your alognment should be staggered/split.
if you are on flat roads and bot doing auto cross etc., i would use.
camber - negative 4 - 5.
caster - positive 2.0
toe in 3/16"
7991LXnSHO
wanna catch the space herp
7,387
2,746
194
Kearney, NE
Aug 25, 2014
  • Aug 25, 2014
Do you have stock height and width tires and wheels? New, wide and low profile radials will likely respond differently to specs than the bias donuts it came with. An experienced shop should have a good feel for what you need. If the alinement machine operator is younger than your daily driver, find another shop.
C
CHEAP CHARLEY
NORTH CAROLINA
Aug 26, 2014
  • Aug 26, 2014
Thanks fer your feedback guys. Yes, the alignment tech was younger than my daily driver. He only knew what the laser alignment machine told him. Another shop told me that 67 spindles would not fit a 65 because of a wider wheelbase, but there "are" installed. It is so hard to get good help nowadays. Most shops are only parts changers, not true mechanics. Anyway I solved my issues by using a borrowed toe board and a tape measure. a few passes on some flat road & a few roadside adustments (the fenders were removed) the car now tracks true.
Thanks again.
7991LXnSHO
7,387
2,746
194
Kearney, NE
Aug 26, 2014
  • Aug 26, 2014
There is you proof that a new laser tool is only as good as the user. I have never had guts to do it with a tape measure and a couple of boards, but I know folks who get the best results that way. An old Bear Alinement shop with a competent mechanic is my preference. Of course, you are lucky to find a kid who can change your points or do anything pre OBDII also.
L
New here from Maine
  • lobster
  • Mar 2, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 5, 2026
lobster
L
G
Need tuning help with 4100 Carburetor
  • Gary’s 67
  • Aug 18, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 22, 2026
manicmechanic007
Suspension Setting Front Alignment - Do I care about the rear's thrust angle?
  • dan50
  • Nov 27, 2025
Fox 5.0 Mustang Tech Nov 28, 2025
Kid wita 5oh
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
M
Hello all, I am new to this forum
  • Maddog 302
  • Dec 19, 2025
  • The Welcome Wagon
The Welcome Wagon Dec 20, 2025
nickyb
