I’m using an Autolite 4100 on my 67 Mustang coupe with a 302 engine and mild 268 cam. I can’t get enough idle rpms to run without cranking on the idle stop screw and getting into the transition circuit of the carburetor that makes the idle mixture screws useless. I’ve got the initial timing set to 13 degrees. I don’t know what the correct fix for this would be. Any help would be appreciated
