alignment woes
  • Thread starter Thread starter bsedwebt70-5.0
  • Start date Start date Nov 30, 2006
bsedwebt70-5.0
320
Charlottesville, VA
Nov 30, 2006
  • Nov 30, 2006
1970 w/ 5.0 FI, negative camber wedge kit with dropped upper control arms by 1 3/4 inches, all NEW control arms, bushings, tie rods, heavy duty front and rear sway bars, Granada disc brakes, etc... 9k miles ago when restored. Car has NEVER been hit - rust FREE garaged kept 302 2v California car from a 78 yr old owner when I bought it 6yrs ago - even had original paint! Shock towers had no cracks in them when I had the engine out and I don't see any now - but I am suspicious of them collapsing. Car is rarely driven and when it is I drive like grandpa. I have not hit any potholes, taken quick corners, etc... Since the car is now EFI the export braces were replaced with home fabricated metal pipes from each shock tower to the fire wall with a heavy metal plate and an monte carlo bar was installed. I am suspicious that the metal pipe export braces have allowed the shock towers to twist and move but the fender gaps have not changed. Car had been driving perfectly for 9k miles but over the past 100 miles it has been making a progressively worse screech sound when driving with even a slight corner. I looked at the tires and they have now got feathered/angled wear toward the inside edges of the front tires -- they had perfect wear patterns on my last oil change/lube 500 miles ago. The wheels now seem to be slanted in at the top on both sides with the right front wheel 1 finger width further forward of the wheel opening rear edge than the left side - but that measurement will be different if I drive the car a block and check it again on a different surface. Also the right front wheel seems to be pointing like it is turning slightly to the right when the left front wheel is pointed straight. Any words of wisdom?
krash kendall
1,258
Aldergrove, B.C. Canada
Nov 30, 2006
  • Nov 30, 2006
It sounds to me like your upper control arm cross shaft bushings are shot. Just pull the wheels off and have a look. They sometimes get so bad that the UCA rubs the inside of the shock tower and wears a hole in to the engine bay. This problem would have all the symptoms you are describing: screeching tires while turning, reverse appearing camber, different camber after driving, and so on.
geostang351
946
Danb., CT
Nov 30, 2006
  • Nov 30, 2006
Is the monte carlo bar fabricated (homemade) or is in original or after market? If the monte bar is home made, it could have been made incorrectly. If this was bought from a merchant, the monte carlo never fits as the shock towers have slightly collapsed or sagged. The Monte Carlo bar is made correctly but the car needs to be put back into its original shape.
What I'm getting at is if its home fabbed, it was problably made incorrectly and the car is slightly settling more. What kind of monte bar do you have?
68 Coop
104
Mesquite, NV
Dec 1, 2006
  • Dec 1, 2006
Not the case with my car, I've bought both styles from NPD, and they fit like a glove. I had the straight chrome one, but didn't like that I had to take it off to do any distributor work. So I bought the curved black one, which is easier to maintain, and it made changing plug wires a breeze.
bnickel
5,640
lubbock, texas
Dec 1, 2006
  • Dec 1, 2006
actually it sounds too me like the lower control arm eccentrics have slipped. actually a pretty common problem. this is the reason why the boss 302 race cars had specially made engine crossmembers that connected to the LCA bolts as well the frame, to keep the LCA's from slipping. if the eccentrics bolts are original it's probably time to get them changed anway. when they start getting old, they don't hold as well. i also always double nut them to help keep the nuts from backing off.
bsedwebt70-5.0
320
Charlottesville, VA
Dec 2, 2006
  • Dec 2, 2006
Thanks guys - the monte carlo bar is homemade - it was fabbed while the engine was out of the car - same as the export braces - homemade too. All of the suspension was rebuilt or replaced including the upper control arms, ball joints, upper control arm shafts (90* grease fittings installed) etc... I am suspicious of the eccentrics and have ordered Pro Motorsports eliminator kit - soon I will find out....
geostang351
946
Danb., CT
Dec 2, 2006
  • Dec 2, 2006
WHile your at it, why don't you change the export and monte arlo braces as well?
bsedwebt70-5.0
320
Charlottesville, VA
Dec 3, 2006
  • Dec 3, 2006
I am doing the export brace now too - I just recieved a "U" shaped black one from my favorite vendor but it will have to be modified to fit around the upper intake plenum for the fuel injected 5.0 I think - that will take a while.
geostang351
946
Danb., CT
Dec 3, 2006
  • Dec 3, 2006
Check out this thread for export braces w/EFI
http://forums.stangnet.com/showthread.php?t=611568&highlight=EFI+export+brace
M
MitchGT
204
Dec 3, 2006
#10
  • Dec 3, 2006
  • #10
wheel bearings?
bsedwebt70-5.0
320
Charlottesville, VA
Dec 4, 2006
#11
  • Dec 4, 2006
  • #11
I had not thought of wheel bearings - I like that E-bay brace from Laurel Moutain - I still wonder if the "bar" export brace part will let the towers flex and twist - the "flat" style with waves built in them like the one piece Shelby unit seem to be the best idea to avoid the twist... I will be doing a combination of eccentric eliminators, export braces, checking all mounting bolts, bearings, etc..
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
