alignment????
  • Thread starter Thread starter 87fab
  • Start date Start date Jul 5, 2006
87fab
51
Dallas,Texas
Jul 5, 2006
  • Jul 5, 2006
Ok,tomorrow I'm getting this thing aligned. I put an Eibach Pro-Kit on & it lowered the front 1.2 inches & the back 1 inch. Does anyone have any suggestions?
795.0pacecar
lover of pudgy polygamists
Jul 11, 2003
480
Senoia, GA
Jul 5, 2006
  • Jul 5, 2006
Did you get caster camber plates?
Before you leave the alignment place make sure you look at the rack and check the dust boots, alot of alignment techs dont feel that its nessisary to unclamp the dust boots, so they become twisted up and can rip open, sometimes when they actually do unclamp the boots they break the clamps, make sure they re-clamped them.
Drive the car around and if it feels off at all bring it back.
I have never had good luck with alignment shops so now I just do it myself at school, you wouldn't believe how crappy some alignment jobs are performed. I aligned my car myself a couple weeks after bringing it to an alignemnt shop and but tie rod jam nuts were lose and the toe was way out, not to mention the dust boots were all twisted up.
Thanks for nothin Big 10 tires.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Jul 5, 2006
  • Jul 5, 2006
Many alignment "techs" are just a step above, or even less than oil changers. Most just "toe and go". There are a few out there that are good.
You might need C/C plates to get it right. If the alignment tech doesn't know how to use them, well, thats one of the ones you don't want touching your car. A real alingment tech will LOVE the C/C plates.
Sometimes, a bumpsteer kit is nessasary, some use offset rack bushings, but generally, lowering can effect the geomertry of the tie rods, which will make it "steer" when you hit a bump.
96SVTpilot
82
Spanaway, WA
Jul 5, 2006
  • Jul 5, 2006
If you don't have the CC plates they won't be able to get the camber back to within specs and you'll start to eat up your front tires. There is no adjustment in the factory plates.
795.0pacecar
Jul 11, 2003
480
Senoia, GA
Jul 5, 2006
  • Jul 5, 2006
There is some adjustment in the factory plates, but not much. With my stock plates and my car being lowered quite a bit, I can get 1 degree of negative camber out of the driver side, but non on the passenger side, I can get a ton of positive camber on the passenger side, but thats no good, so I need caster camber plates.
87fab
51
Dallas,Texas
Jul 5, 2006
  • Jul 5, 2006
No I did'nt, these guys are asking about adding a cam...appearently whare the strut bolts up at the bottom ,the holes wear out and they sometimes require these,"cams" I did ask about cast&camber plates and they said they would do what they could without adding them,but they did say that they prefer them.
Mustang5L5
Mod Dude
Feb 18, 2001
43,377
18,123
224
Massachusetts
Jul 5, 2006
  • Jul 5, 2006
Get them. When you start eating front tires up you'll end up finally getting them and then having to get the car aligned again
87fab
51
Dallas,Texas
Jul 5, 2006
  • Jul 5, 2006
Any suggestions on a good brand??
87fab
51
Dallas,Texas
Jul 5, 2006
  • Jul 5, 2006
Can toy suggest a good AFFORDABLE brand??
795.0pacecar
Jul 11, 2003
480
Senoia, GA
Jul 5, 2006
#10
  • Jul 5, 2006
  • #10
www.stangsuspension.com Any one of the caster camber plates they sell are pretty good.
87fab
51
Dallas,Texas
Jul 5, 2006
#11
  • Jul 5, 2006
  • #11
$160....wonder if ebay would have them for less.
302RollinHard
Columbus, OH
Jul 5, 2006
#12
  • Jul 5, 2006
  • #12
Sounds to me like the shop has a decent idea as to what they are doing. See what they can do. As stated above, there is some adjustability (involves grinding of rivets, etc) there, but no use buying them unless you need them. I put the pro-kit on mine, and got away without them. I also watched the guy do it all, so I am pretty confident he did it correctly.
795.0pacecar
Jul 11, 2003
480
Senoia, GA
Jul 5, 2006
#13
  • Jul 5, 2006
  • #13
$160 is a realy good price. Remember you get what you pay for and your suspension is definatly an area you dont want to cheap out on.
87fab
51
Dallas,Texas
Jul 5, 2006
#14
  • Jul 5, 2006
  • #14
Ok, I'm going to chance it and just get it aligned and if it works out....Kool! if not...then i know my next move.
87fab
51
Dallas,Texas
Jul 5, 2006
#15
  • Jul 5, 2006
  • #15
I agree, I'm pretty anal about the slightest vibration,pull,humm,etc. I tend to sound cheap because...well I am.(wife,kid's,bills....mustang)
Resolved 2015 ecoboost pp bumpsteer issue
  • matthewt
  • Aug 1, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Aug 3, 2026
fasterthangas
F
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
Suspension Setting Front Alignment - Do I care about the rear's thrust angle?
  • dan50
  • Nov 27, 2025
Fox 5.0 Mustang Tech Nov 28, 2025
Kid wita 5oh
