All AOD's equal?
  • Thread starter Thread starter JohnVH
  • Start date Start date Feb 22, 2006
JohnVH
816
Lynden, WA
Feb 22, 2006
  • Feb 22, 2006
All AOD's equal?---- did swap, now question..
Hi all, I have a '93 lx 5.0 and the trans has no overdrive anymore. Ive found a AOD from a '89 and want to make sure there wont be any problems putting it in my car.
Thanks
rsw007
469
Lexington,SC
Feb 22, 2006
  • Feb 22, 2006
93's had different direct drum"internal" so yes all the 79-93 aods will swap out.
RYC CUKR
1,437
Orlando
Feb 22, 2006
  • Feb 22, 2006
the 92-93, I believe that I am correct on the years, have a stamped steel drum while the earlier models have a cast iron drum. But it is an internal thing and you should be able to unbolt the old one and bolt in the new.
timewarped1972
642
mesa, az
Feb 22, 2006
  • Feb 22, 2006
the speedo drive gear in the tranny is different too i believe........84 to 89 is one drive gear, 90 to 93 another....in a 90 to 93 aod you can only get the correct speedo gear for up to 3,55 gears unless you swap the old speedo gear drive from the 89 in
they did that with the t-5 too, why ford changed something like that i have noooooooo clue
JohnVH
816
Lynden, WA
Feb 22, 2006
  • Feb 22, 2006
OH, Ill have to get the gear off the ;89 car.. thanks!
timewarped1972
642
mesa, az
Feb 22, 2006
  • Feb 22, 2006
just to clarify it's the internal drive gear in the tranny tailshaft........of the tranny.......not the speedo gear itself, just incase i said that wrong.......
JohnVH
816
Lynden, WA
Mar 5, 2006
  • Mar 5, 2006
OK, just finished the trans swap today. I used the converter and the speedo gear for the '89. Finally have overdrive now!
But,couple things.. on my way to change them I noticed I did 40mph at 2500rpm in 3rd gear. Now its 40mph and 2000rpms if I remember right. I swapped the speedo gear, could it just be the trans has a different ratio?
Other thing, the trans shifts sooner than the other one, is there a way to adjust the shift points?
And thats all I can think of right now. Took me longer fiddling with that stupid emissions tube on the H pipe than it did to swap the trans.... Time for an off road!
rsw007
469
Lexington,SC
Mar 5, 2006
  • Mar 5, 2006
tv cable mihgt need to be fine tuned. tranny ratios on the aods are same the 89 might have had a different rear end ratio than yours. or your old tranny was slipping
JohnVH
816
Lynden, WA
Mar 5, 2006
  • Mar 5, 2006
Ahh, ok, Ill do some searching on how to adjust a tv cable.
I dont think my other trans was slipping, but not sure my speedo is correct, Ill check it today with my radar gun.
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
