almost lost it
  • Thread starter Thread starter rockyracoon
  • Start date Start date Oct 22, 2009
R
rockyracoon
874
27
49
margate NJ
Oct 22, 2009
  • Oct 22, 2009
I was driving home in the mustang,accelerating around a slight curve at about 50 mph,and when I went to navigate through the curve the car almost went out of control,it wasnt sliding or anything it was almost like I oversteered and when I went to correct it wanted to go out of control in that direction.
I recently replaced the inner and outer tie rod ends,and I also recently swapped in another rear drum to drum.
I couldnt tell if it was the back end or the front end that wanted to go south.it scared the hell out of me,there is definetly something wrong.
the car just seems to be unstable from front to back.
could it just be that an alignment is needed?
87GT Drop Top
500
South Florida
Oct 22, 2009
  • Oct 22, 2009
If you didn't get it aligned then that is your problem. If the toe is off it will act like you describe.
91stalker
51
GA
Oct 22, 2009
  • Oct 22, 2009
QUADRABIND in action my friend. Under hard turning at speed, the rear end will bind up and feel like its trying to steer the front of the car and feel like you are oversteering. Sounds kinda like what you experienced, it happened to me in a turn goin about 70 and I needed to change my pants... Dont really know how to cure this - I'm sure someone can chime in and help out, but from what I understand a panhard rod and torque arm will eliminate this from happening again.
2000xp8
SN Certified Technician
Aug 8, 2003
8,073
1,656
194
NJ
Oct 22, 2009
  • Oct 22, 2009
Panhard bar is the solution, sounds like you had some snap oversteer. It happens to everyone at least once, you'll be more cautious next time, i'm sure.
You don't need the torque arm to use the panhard bar.
For starters, make sure all your bushing are good in your rear control arms.
G
GDTrumbo
199
Nashville, TN
Oct 23, 2009
  • Oct 23, 2009
I have the MM panhard rod kit. 11 hr install myself. Beautifull addition!
Very predictable handling now. Should have been standard issue for all Mustangs from '79 - '04.
I wonder how many "mid curve" accidents could have been easily avoided
with it. My wife had a cousin in Michigan die in a Mustang vert a few years ago navigating a curve.
GT
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Lost my Foxbody
  • Mhalc1
  • Feb 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 17, 2026
Mhalc1
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Foxbody adjust alignment
  • Creomod
  • Jun 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 14, 2025
2000xp8
