Alright folks, 1 more code and i'm clean.
Rerun
312
South Bay, California
85, canister purge solenoid. The solenoid has been removed, I'm going to buy a new one. I understand that there's an electrical connetion near the intake. My question is, there's also a line that runs from the fuel tank up to the solenoid? There's 1 line on the actual canister itself, it appears to goto the passenger side vacuum setup. Thanks fellas.
The soleniod and connector for it is right at the canister. There should be a hard plastic black line that runs along the frame rail to the canister from the tank, and then there is a hose with the solenoid on it, that goes to a vacuum port on the intake somewhere. Usually I think it's right under the intake. Hope this helps.
