  • 1994 - 1995 Specific Tech
Alt fuse blowing at WOT, what is going on there?
  • Thread starter Thread starter 99FiveOh
  • Start date Start date Feb 24, 2009
First Prev 2 of 2
toyman
1,944
54
79
Vernon BC
Mar 14, 2009
#21
  • Mar 14, 2009
  • #21
The_Mustang said:
That statement wasn't made by me, it was made by Toyman. Further, when I was talking RPM's I was stating that when my tach in the car would reach 5K, it would blow my alt. fuse.
And I believe I understand what you were trying to say. You were talking about the relationship between the rotor in the alt and the alternator pulley and that they spin at the same speed. That is correct. But if the engine is turning 5000 rpms, then Toyman was trying to say the alternator itself is probably turning 10K rpms.
Correct, if the engine is turning 5000 rpm then the alternator is turning 10K+. I don't recall the formula for determining centrifical and/or tangental forces but I'm guessing they increase expodentially so the stresses on the rotor/armature are a lot greater than simple math would indicate. I was mentioning this as it was noted that a soldered connection had broken and at 5000 (crank) rpm the loose connection started to short against the housing.
HISSIN50
34
129
Mar 14, 2009
#22
  • Mar 14, 2009
  • #22
Should be able to get alternator RPM with:
[Crank pulley/Alt pulley] x Engine RPM
3G's dont like more than about 15K alternator RPM
99FiveOh
2,051
20
99
J-Ville, FL
Mar 14, 2009
#23
  • Mar 14, 2009
  • #23
either way, it's charging perfectly now and I redlined the car and zero alt fuse poppage (is that a word????)
First Prev 2 of 2
W
Strange connector near fuse box
  • W4rl0ck
  • Sep 23, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 28, 2026
gkomo
G
Help! Radio, door chime fuse keeps blowing.
  • goofyfoot53
  • Sep 9, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Sep 9, 2025
91AOD5.0LX
F
2003 Mach 1 - F1.28 Fuse blows on KOEO
  • fr500mach
  • Jul 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 19, 2025
fr500mach
F
Big Posi and Neg wire from Starter to Battery and Alt wires..........
  • from6to8
  • Feb 9, 2026
1994 - 1995 Specific Tech Feb 9, 2026
AeroCoupe
Electrical Need help identifying what these electrical items are (93 LX 5.0)
  • dan50
  • Apr 11, 2026
Fox 5.0 Mustang Tech Apr 12, 2026
dan50
