ALT problems, help please!
  • Thread starter Thread starter 1SLO306
  • Start date Start date Dec 4, 2005
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
Dec 4, 2005
  • Dec 4, 2005
my alt was not chargin the battery all that great. so i pulled it off to check the brushes. Sure enough one was completely gone and one was barely there. I put in new one and now the thing isnt charing at all. Could i have blown the voltage regulator???
Dbeck002
710
South florida
Dec 5, 2005
  • Dec 5, 2005
how did you check the brushes? did you take the whole alternator apart?
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Dec 5, 2005
  • Dec 5, 2005
Have you checked to see that you have voltage coming out of the Alternator? Maybe you have a bad wire / connection. Small things like this lead to overworked alternators and such....
1SLO306
Mar 31, 2005
904
Muhlenberg, ky
Dec 5, 2005
  • Dec 5, 2005
all i have to do is take the voltage regulator off and there is my brushes. How can i check to see if its puttin out volts?
djk8705
154
Fairfax, Va
Dec 5, 2005
  • Dec 5, 2005
If its off the car a simple bench test will tell you if it is the problem or a simple wiring issue... advanced auto/pep boys.. lots of places do free tests around me
skip nay
110
Chambersburg Pa
Dec 5, 2005
  • Dec 5, 2005
If it is on the car take a voltage gauge or meter to the out put wire or too the plug itself
srothfuss
Oct 17, 2004
1,796
Woodward Ave.
Dec 5, 2005
  • Dec 5, 2005
I guess I wasn't thinking this morning. A simple continuity test across the wires in the engine bay will establish that you still have an electrical path between the alternator and battery.
Something that will help is upgrading all of the grounds on the car. The alternator is grounded through the engine which is inturn only grounded by 1 or 2 thin metal straps.
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
Fox Jump/start - Charging
  • PonyGTrider
  • Oct 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2025
PonyGTrider
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
