  • 1994 - 1995 Specific Tech
alt removal, stupid question?
  • Thread starter Thread starter ronstang94
  • Start date Start date Apr 14, 2008
ronstang94
204
Phx, AZ
Apr 14, 2008
  • Apr 14, 2008
maybe it is because I have only had two hours of sleep in the last 40 hours, but i cannot get the alt out of the car. Belt off, top bolt out, bottom bolt out, little bolt on back side that holds the air injection tube bracket up removed, all wires/plugs removed.
it is stuck at where the bottom bolt was. It pivots at that point, but wont come out. On the front of where the bolt went in, there is like a small section of thick wall tube sliced down one side in the bracket (the bolt goes through the tube), I tried to pull the tube with plyers, and tried to pinch it to get it out but no luck.
Thanks
ronstang94
204
Phx, AZ
Apr 14, 2008
  • Apr 14, 2008
nevermind, I got it.
Vice grips
Is that normal, that little tube because my haynes manual did not even mention it?
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Apr 14, 2008
  • Apr 14, 2008
It's normal, we all have it. I'm not sure why it's used, seems a bit odd to me.
HISSIN50
34
129
Apr 14, 2008
  • Apr 14, 2008
The pivot bushing always is a hang up (you'll find them on almost all alts). In the future if you can, rock the alt in it's cradle (longitudinally) and the pivot moves enough to allow the alt to fall out.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Apr 14, 2008
  • Apr 14, 2008
I had to pry my alternator out of the bracket. It's a tight fit. Putting it back, I had to use a rubber mallet and a couple of light taps to get the bolt hole aligned.
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
M
  • mnky99
  • Sep 5, 2025
mnky99
M
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
D
How to remove the differential from a 94 Mustang GT Coupe
  • dcm0123
  • Apr 10, 2022
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 10, 2022
dcm0123
D
Help Radio replacement stock 1997 4.6 Dolby mach & a/c bezel removal
  • blkconv4697
  • Jun 18, 2022
1996 - 2004 SN95 Mustang -General/Talk- Jun 21, 2022
manicmechanic007
