Alt wiring question?
  • Thread starter Thread starter RsStanG1987
  • Start date Start date Jul 16, 2008
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
Jul 16, 2008
  • Jul 16, 2008
Is there a way to use a newer alt in an 85 gt? What wires would go where?
RsStanG1987
569
9
79
Dupont PA
Jul 16, 2008
  • Jul 16, 2008
bump
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 16, 2008
  • Jul 16, 2008
3G install into an 85 or earlier Mustang:
I would recommend the addition of a 2 amp fuse on the Light Green/Red wire that goes to the switched ignition.
I would use a maximum of 150 amp fuse for the output wire that connects to the starter solenoid.
jwzg
237
Prattville, AL
Jul 16, 2008
  • Jul 16, 2008
jrichker:
1) Why does the factory run a fuselink on the yellow wire and send it all the way to the solenoid?
2) I thought the factory green w/red runs to the amp meter. Why put a fuse there?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 16, 2008
  • Jul 16, 2008
jwzg said:
jrichker:
The yellow wire is sense voltage for the regulator. It is supposed to compensate for any small volage drop across the power feed wiring. Fusing it protects the wiring should the regulator have an internal failure and short to ground.
The green/red wire is the Run sense wire that is used to turn on the regulator. Fusing it protects the wiring if it develops a short or if the regulator has an internal failure and shorts to ground.
Console wiring plug
  • beerslob
  • Jul 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2026
apple99Mustangdude
A
Electrical Need help identifying what these electrical items are (93 LX 5.0)
  • dan50
  • Apr 11, 2026
Fox 5.0 Mustang Tech Apr 12, 2026
dan50
Electrical 91 hatch wiring help needed
  • FastDriver
  • Apr 7, 2026
Fox 5.0 Mustang Tech Apr 8, 2026
FastDriver
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
79 with 130amp alt
  • 5ptslow
  • Nov 22, 2025
  • Fox Engine Swaparoo
Fox Engine Swaparoo Nov 22, 2025
rednotch
