alternator help
32785stang
30
ok I have an 85 mustang gt and i need to up the amps on my alternator. the stock on is like 45 ams loli need like a 140. problem is all the ones that high are internally regulated. mines external. whats the easy way to do this. if someone has a wiring diaghram that would be tits, if not just walk me through it....the one i have has three terminals on the back side if the alt. not that big plug on the top like the 87-93
attachment.php
Use a 4 gauge power wire, and a 125-135 amp fuse. The wiring and fuse are off spec on this drawing . Use a 4 gauge ground wire from the front of the block where the battery ground is to the chassis ground up near the battery.
Picture courtesy timewarped1972
so what year alternator would i have to ask for when i order it?
Jrichker showed you how a 3G can be wired up for your purposes (instead of using conventional 3 wire voltage regulator wiring, the stator and battery terminals are individually looped to lessen the wiring needed. This creates basically a two wire connection).
You would then simply adapt this to your vehicle (run a new fused power cable and source a key-on hot wire which runs through resistance before going to the regulator's I terminal).
Good luck.
