Alternator Hook Up?
Need help!
I'm installing a -87 HO, with -89 HO Electronincs (mass air) in a AC Cobra build. I bought everything used and imported it to Sweden. I have connected everything now, but I'm missing parts and knowledge how and where to connect the alternator. Both connectors..?
See attached picture (don't mind the colour..)
Please fill in my lack of knowledge
Best regards
magna_swede
This may help...
attachment.php
Starter solenoid wiring for 86-91 Mustang
attachment.php
Starter solenoid wiring 92-93 Mustang or earlier Mustang with upgraded high torque mini starter.
attachment.php
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
Reactions: magna_swede
Thanks a lot! :)
Now I've got several input that state that I should go for a 3G alternator instead. (-94-95 130 A) So thats what I'm looking at right now. Found a dussin at the salvage-website here. What I recongise is that the D-connector still is ther and then one main. Any detailed description on this? :confused:
You want to find the following 3g alternators.
130 Amp Alternators (Grab Pigtail if you can)
Mustang 3.8L (94, 95, 96, 97, 98, 99, 00)
Mustang 5.0L (94, 95)
Taurus/Sable 3.0L (93, 94, 95, 96, 97, 98, 99) except sho
Thunderbird/Cougar 3.8L (94, 95, 96, 97) non sc
If you are having trouble finding one in a junkyard, Rock Auto sells a new one for about $100 US. Don't know if or how much shipping is to Sweden.
http://www.rockauto.com/catalog/x,carcode,1134133,parttype,2412
Here's a write that shows you pics, although I strongly disagree with cutting of any wires and do NOT attach the existing power wires from the 2g harness to the post on the 3g alt. You can simply tie into the stator wire with a scoche connector and tape off the existing plug from the 2g. You need to run a 4g wire from the alt post to the + side of the starter solenoid and run a fuse inline.
http://www.racesystems.com/3gproj/
I bought this 4g kit from a vendor on another forum. Buy it- it will save you time and money and has everything you need except the alt.
http://forums.corral.net/forums/ele...ternator-upgrade-complete-kit-small-case.html
