Hey guys, I installed my alternator with all the wires set to jrichkers diagram. Spliced small white/black wire for stator wire, plugged in small connecter, and used a 125amp fuse. Also got a 4g ground going from engine to chassis.
I had a little miss hap when I connected the battery the positive terminal on the alternator was touching the alternator case, so I got some sparks. I look at the fuse in between the lines and it "looks" alright. Its one of these fuses, can you tell if there good just by looking at it?
Im not sure what else it could be. The gauge isnt all the way at the bottom its at the bottom quarter of the gauge, and it has no response when I hit the gas, it used to be at the middle or top quarter with my old alternator, and when I hit the gas it would go up.
Any ideas?
Any ideas?
