ALTERNATOR PROBLEM(PLEASE HELP)
  • Thread starter Thread starter 87SnicBluStang
  • Start date Start date Nov 17, 2004
87SnicBluStang
new York
Nov 17, 2004
  • Nov 17, 2004
Ok, here is the problem the alternator will charge, but then will begin to stop charging, and it will not begin to charge again, and it doesn't always charge when the car is started. I was wondering if anyone has had this problem before and if anyone has any ideas on what this problem could be. No lights go on indicationg my battery is dying, except for the fact that my dashboard lights, and exterior headlights start to dim while I'm driving and the engine's power comes down quite a bit...
**The battery is brand new, the altenator is brand new (I kno it is possible the Alternator can still have a defect, but it's a less likly option)**
Any Ideas would be appreciated, if you have any questions, I can try to explain this more fully to you, but any ideas are great... thank you!
86T-Top
553
Dublin, PA
Nov 17, 2004
  • Nov 17, 2004
I would check the connection of the black and organge wire. I had a problem where the two black an orange wires joined into one on my car. The connection burned up there, and the alternator was not able to charge my battery.
Mario
86StangLX
52
  • Nov 17, 2004
If the alternator is going in and out like that I would say you have a bad ground. Alternators either work, or they dont. If you want, take your car to an auto store that can load test your charging system. This may help you diagnose the problem. I would check your battery ground, though. It sounds to me like you have a bad ground, and it's causing intermittent problems.
cdog301
236
richmond ,ca
Nov 18, 2004
  • Nov 18, 2004
charging
86StangLX is right I had the same problem and it was the ground wire to the block! replace with low guage wire (less resistance)
HISSIN50
34
129
Nov 18, 2004
  • Nov 18, 2004
ya positive the power cable for the alternator is attached securely?
good luck.
Rockin302
236
California
Nov 18, 2004
  • Nov 18, 2004
To add my 2 cents. Check the belt tensioner, if it's gone bad, it may cause the belt to slip a bit and your alternator won't be charging the batt. correctly like it should.
J
JB66
565
New York
Nov 18, 2004
  • Nov 18, 2004
One more...
I've seen a lot of bad connectors lately. If there's any question, replace the connector(s) on the alternator wiring at the alternator.
87SnicBluStang
new York
Nov 23, 2004
  • Nov 23, 2004
Thanks for the help guys! I figured it out, it turned out to be the plugs that go into the altenator themselves were bad, and I heard they need sum replacing after a while, i did that and it works fine now, thanks for the help!
Electrical Alternator not charging after terminator 2 install.
  • Sfab79
  • Aug 24, 2025
  • 2 3
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
C
Stock 1993 charging issue at idle
  • Charlie1
  • Sep 21, 2025
Fox 5.0 Mustang Tech Sep 24, 2025
Mustang5L5
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
