  • SN95 4.6L Mustang Tech
Alternator Problems
  • Thread starter Thread starter Flghtmstr1
  • Start date Start date Aug 13, 2012
Flghtmstr1
572
Springfield, PA
Aug 13, 2012
  • Aug 13, 2012
I've been trying to get the Mustang ready for the dyno, and I've been having persistent alternator / charging system problems. I've gone through three alternators now, and they all had the same problem: they don't seem to be charging the battery even though the idiot light seems to be working properly (key off indicator off, key on indicator on, engine on indicator off). Key off battery voltage is 12.6, but it drops to 12.2 when the engine is turned on, and revving the engine up to 2000 rpm doesn't change the battery voltage at all.
I've verified that the black and orange positive wire has continuity with the B+ terminal, and the alternator case has continuity with the B- terminal. I've checked the fuse in the junction box and the fusible links (both visually and with a multimeter) and they all seem fine. I've also checked the yellow and green wires going into the alternator by back-probing the connector. They read as follows:
Key off:
Yellow/white: 12.6v
Green/red: 0v
Key on:
Yellow/white: 12.2v
Green/red: 1.6v
Engine on:
Yellow/white: 12.2v
Green/red: 11.2v
Needless to say, I'm stumped. The only thing that looks sketchy is the engine on green/red measurement, but I'm not sure what to make of it. Any ideas?
N
n0v8or
604
Rhode Island
Aug 14, 2012
  • Aug 14, 2012
I may be missing something obvious, but I can only come up with 2 possibilities. Well, perhaps 3.
That the lamp turns off but the battery does not charge is an indication that the alternator is developing voltage, but charge current is not flowing. My first choice is a defect (perhaps not a complete break) in the black-orange wire that runs between alternator and battery. Second choice is a poor connection between alternator frame and battery negative.
The second possibility is easiest to eliminate. Connect a jumper cable between the alternator frame and battery negative post. Be careful to lay the wire where no moving parts can contact it when starting the engine. If nothing changes, that's not the problem.
To check the black-orange wire resistance, you need to pull back the rubber boot enough to get your positive voltmeter probe on the alternator output terminal. If it reads more than 1-2 volts higher than the positive battery post, (engine running) there is either excess resistance in the connection or an unusually high current drain. I know you checked continuity, but even 0.5 ohm would prevent the battery from charging with the engine running. The ignition alone draws ~10A, which would mean a ~5V drop across 0.5 ohm.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Aug 14, 2012
  • Aug 14, 2012
I want to go out on a limb and go a different direction. Are you positive that the CORRECT alternator for your application was used?
Some Ford alternators have different wiring and have a separate "I" and "S" circuit. These alternators will not work in a Mustang without jumping the "I" and "S" together.
Flghtmstr1
572
Springfield, PA
Aug 15, 2012
  • Aug 15, 2012
How can I tell if the alternator is correct? I got it from Auto Parts International (I assume it's reman).
Flghtmstr1
572
Springfield, PA
Aug 15, 2012
  • Aug 15, 2012
I checked the black-orange wire's voltage with the engine running, and it was 12.2, same as battery voltage. I'll try the jumper cable trick when I get home from work today.
N
n0v8or
604
Rhode Island
Aug 15, 2012
  • Aug 15, 2012
Burns has won me over (once again). Given the history of multiple alternator replacements with no change in symptoms, his idea is more plausible than mine.
Admittedly, I am grasping at straws here. I have seen some Mustang alternators with a right angle adapter that bolts to the output termunal. If you had to re-use the same adapter with all of the replacementy alternators, and it was damaged internally, then all alternators would produce this same symptom. Of coourse, if your original alternator did not have this adapter, or the replacement alternators came with a new one already attached, then forget I even mentioned it.
Flghtmstr1
572
Springfield, PA
Aug 15, 2012
  • Aug 15, 2012
I have been throwing away those adapters, as my setup doesn't require them.
Flghtmstr1
572
Springfield, PA
Aug 15, 2012
  • Aug 15, 2012
I tried jumping from the alternator case to the negative battery terminal, and it didn't change a thing. WMBurns, what did you mean by separate I and S circuits? How can I check to see if my alternator is correct?
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Aug 16, 2012
  • Aug 16, 2012
The alternators used in Mach1 applications and other Ford applications have 3 active connections on the small connector. Some Mustangs use a connector with (3) terminals but there is a jumper going to the middle pin. The wire color is WH/BK.
The alternator will only use pin 1 and 3. So you might try jumping pin 3 and 2 and see what happens. I would use a jumper with a safety fuse just in case.
Also, what if the small connector isn't really making a good connection? This would keep the alternator from powering up. Have you really looked at the connector to see if there are any bent/pushed/dirty pins?
Consider getting yourself a full set of Ford wiring diagrams. I can help. PM.
Flghtmstr1
572
Springfield, PA
Aug 17, 2012
#10
  • Aug 17, 2012
  • #10
The alternator will only use pin 1 and 3. So you might try jumping pin 1 and 2 and see what happens. I would use a jumper with a safety fuse just in case.
The alternator has 3 pins and the harness has a 3-pin connector with pins 1 and 3 occupied and pin 2 empty. What, exactly, should I try jumping? I have the Ford wiring diagram, but electrical systems aren't my strong suit.
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Aug 18, 2012
#11
  • Aug 18, 2012
  • #11
Look at your wiring diagrams. Jump the +12 volt supply pin #3 (YE/WH) to pin #2. Note, it won't hurt anything to jump pin #1 to pin #2 (especially if a fused jumper is used).
Flghtmstr1
572
Springfield, PA
Aug 23, 2012
#12
  • Aug 23, 2012
  • #12
Sorry it took so long for me to respond; I wasn't able to work on the Mustang all week.
I don't think there's any way to access the #2 pin when the harness is plugged into the alternator because the harness-side connector does not have a pin in the #2 slot. It has a recess for the alternator-side pin to fit into, and this recess is sealed from the outside by the plastic connector body itself. The only way to access the pin with the connector plugged in would be to drill a hole in either the connector or the alternator itself, which is obviously not something I am willing to do.
I did notice that the alternator pulley gets extremely hot (too hot to touch) after only 1 minute or so of engine run time, while the alternator case itself remains relatively cool to the touch. I'm not sure if that tells us anything, but it seemed strange to me.
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Aug 24, 2012
#13
  • Aug 24, 2012
  • #13
The #3 is the dash charge alarm so it's not required to power up the alternator. So try taking the small connector out and power pin #1 and #2 directly from a fused jumper.
Flghtmstr1
572
Springfield, PA
Aug 27, 2012
#14
  • Aug 27, 2012
  • #14
Turns out it was the wrong alternator. Nice call wmburns!
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
P
Electrical 2001 GT Overcharging
  • PseudoGT
  • Dec 3, 2025
SN95 4.6L Mustang Tech Dec 13, 2025
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
F
Alternator Not Charging
  • Fri Guy
  • Aug 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 31, 2025
AeroCoupe
