Alternator question
  • Thread starter Thread starter oldfordguy
  • Start date Start date Sep 24, 2007
oldfordguy
11
Da windy city
Sep 24, 2007
  • Sep 24, 2007
OEM alt style just went bad. Should I move from 3 wire to 1 wire? What about going up in amps to 100. Would I have to also upgrade wiring? I don't have a bunch of add ons to draw power , moderate stereo. I've seen some nice 100amp chrome 1 wire on ebay , but is it really worth it , or should I stick with OEM 80 amp?
Blue67fastback
21
Cape Cod
Sep 24, 2007
  • Sep 24, 2007
I went to one wire on both my 66 and 67. Solved my amp problems, I needed it for elec. fan cooling and other add ons. Had trouble with Chrome units, they are slower to dissipate heat.
oldfordguy
11
Da windy city
Sep 24, 2007
  • Sep 24, 2007
Did you move up in amps? if so did you have to rewire much?
rbohm
6,698
550
204
tucson,az
Sep 24, 2007
  • Sep 24, 2007
stepping up to a 100 amp alternator is a good idea. you will have the change the wire from the alt to the battery to an 8 gauge minimum. i recommend actually stepping up to a 3G alternator. there are conversion kits for the wiring available.
jeffnoel
1,638
Clovis, CA
Sep 25, 2007
  • Sep 25, 2007
I swapped to the 100-amp 1-wire to clean-up the engine bay, since there internally regulated you can get rid of the box on the fender.
classic boost
709
canton, oh
Sep 25, 2007
  • Sep 25, 2007
i just switched to a gm 3-wire. 94amp and only $100 from autozone (lifetime warranty). the wiring was easy.
oldfordguy
11
Da windy city
Sep 25, 2007
  • Sep 25, 2007
Thanks all! I hate wiring so avoid messing w/it if I can.
classic boost
709
canton, oh
Sep 25, 2007
  • Sep 25, 2007
i don't blame you there.
the gm alt can be wired as a 1-wire. just goes from the alt to the batt side of the starter solenoid. doesn't get much easier than that.
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
82 Gen 1 Coyote Swap AC Questions...
  • thinkfaster
  • Aug 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2025
thinkfaster
