Alternator Questions...
BusBoy
California
Alternator Questions... SOLVED!
Hey there gang...
I have a 66 conv with a 87 5.0 conversion in it. I wanted to upgrade the stock alternator so I picked up a Powermaster alternator. Now me being a noob and not really wanting to modify the electrical i went with a NON one wire model.
I open the box and go to the garage to install it... hmmmm my stock alternator has two connectors where the new Powermaster doesnt. I am missing something?? The new Alt has the small plug that plugs in no problem but the wiring on the car still has a pigtail and from teh gauge of the wire looks to be the charging ones.
Can someone whos maybe done this swap give me a hand out on this? I can post pics later if needed.
thanks everyone!
Just a guess but maybe the new one is internally regulated whereas the original one was externally regulated?
Heh... i knew my noob factor would creep into this somewhere! :bang: The new one is internally regulated, but I have no idea if the old one was... this was a complete swap so everything electrical on the 5.0 was/is stock.
So I guess my question no is... was the 87 5.0 internally or externally regulated?
ps thanks for the quick reply Kat... rated you up @ cardomain.
A '66?!
Not that I'm an expert but I don't think I've ever seen an internally regulated alternator from that era. hopefully, someone who IS an expert on the subject will jump in here for you.
Oops! Sorry, now that I'm re-reading your post, you're saying that the harness you're using is from the '87. THAT I can look up for you. I'll check it and get right back to you.
A '66?!
Clarification... since this was a 5.0 "Upgrade" into my 66 we just took a complete motor and trans from a 87 and slapped it into the 66... all electrical on the motor is stock... sans the alternator now.
Soooo for a 1987 5.0 did it have a external voltage regulator :shrug:
It was internally regulated. I have the schematic on my computer. What do you want to know?
well theres two plugs on the stock alt and two pigtials on the harness both are/were plugged in...
the new powermaster has one (the small oval one...) which is plugged in. i dont know what the other pig tail is (larger plug 4 wire i think) that was plugged into the stock alt nor where i need to wire it to... Im guessing its the charge wires.
Hard to be 100% sure by the schematic but from what I see, there's basically two main external connections on the '87. One is a Lt. Green/Red wire that goes to the idiot light in the dash, and the other is a group of wires (3 actually) that ALL connect to fusible links (12v+).
Fixed...
here the solution if someome happen to search for this...
Only two wires need to be connected to the new alternator. Cut off both of the stock 5.0 connectors where they Y together into one harness. In the stock 5.0 harness there will be a green/red stripe wire, connect that to the matching green/red stripe wire on the plug that came with the new alternator, cap off all other wires so as not to cause a short. Using a ring terminal, run a new 4 gauge wire off the large stud directly to the positive terminal of the battery.
Fixed...
I'm not so sure that's a good idea. By the looks of the wire sizes, you're only connecting a rather small wire and it won't be able to carry a very big load.
