alternator up grade
  • Thread starter Thread starter noslow1986
  • Start date Start date Mar 12, 2008
N
noslow1986
274
oswego Il
Mar 12, 2008
  • Mar 12, 2008
when putting an electric fan in do i need to up grade my alt. im not running a sound system, just under drive pulleys. for so reason when i start the car cold the idle is low have to keep on the gas for 5 min or so, then its fine. but i will have a tune for emmission so maybe that will help
SummitTech
  • Mar 12, 2008
Typicaly no. If you wanted to upgrade to a 140 amp you could use the PWM-8-47140, however its idle speed output will will only be 80amps. The idle speed is about 2400 rpm at the alternator pulley. To find out what your idle speed is divide the diameter of the crank pulley by the diameter of the alternator pulley. This will be the pulley ratio. Multiply the engine rpm by this ratio to get the alternator rpm. For drag racing this ratio can be as low as 1.75:1 but for street use as high as 3:1 The easiest solution maybe to change the alternator pulley. The March Performance pulley MCH-110 is 1.6875" diameter and would increase your ratio.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 12, 2008
  • Mar 12, 2008
The electric fans have a large startup spike of 90-100 amps that lasts for less than 20 seconds. This can place a large load on the stock alternator. Driving in stop and go traffic on a rainy summer night will likely overtax your electrical system if you use the stock alternator and an electric fan, Here's why..
Figure this:
Ignition system & computer = 12 amps
Fuel pump = 12 amps
Exterior lights = 15 amps
Fan (heater or A/C) = 15 amps (can run between 5-25 amps depending on setting)
Radio & instruments = 10 amps
Wipers = 10 amps
That's grand total of 74 amps from a 65 amp alternator. Talk about overdrawn at the bank!
3G installation link:
See the 3G Alternator Install - Roland69 in the "Useful Technical Thread Index at the top of the 5.0 Tech forum. Everything you need to know is in there.
If you are having idle problems, See "Help me create the Surging Idle Checklist" at http://forums.stangnet.com/showthread.php?t=698148
for help with your idle problems. At last count there were 24 possible causes and fixes for surging idle/stall problems. The first two posts contain all the updates to the fixes. I continue to update it as more people post fixes or ask questions.
TRWXXA
190
RIGHT BEHIND YOU!!!... Made you look.
Mar 12, 2008
  • Mar 12, 2008
Do the upgrade. Your electric fan is most likely going to kick-in when the alternator is producing low current -- low speed or idle.
The stock alternator is barely capable of handling normal electrical loads at idle.
Make sure you upgrade the wiring too. It's an easy job. If you get a small case 3G, the entire upgrade should only take about 30 minutes. A little longer if you get the full-size 3G, and have to grind the bracket for clearance.
Turkey Sammich
I can't fap normal. I cracked a rib, then my ankle
Jul 12, 2006
154
Mar 12, 2008
  • Mar 12, 2008
I'm unclear what ford was thinking when they decided to put in a 65amp alt. and then put in the 130amp in the SSP's.
You'll notice if you put in the e-fan with the stock, get the 3G.
bloopbloob
578
Alberta
Mar 12, 2008
  • Mar 12, 2008
i'd suggest the upgrade even if you were basically bone stock. with an e-fan, i'd highly recommend doing it. not very expensive, and good peace of mind. i did the swap even though my old alt was working ok. the stocker is worthless if you ask me... add a mild stereo, u/d pullies, e-fan, and it's just a matter of time till you're left stranded... just my 2c...
TRWXXA
190
Mar 12, 2008
  • Mar 12, 2008
Actually, the 130 amp alternator was only an available option on the SSPs. As far as I can tell, less than half the SSPs were ordered with it. Mine had the regular alternator in it when it was in service. In addition to the equipment jrichker listed, it had a lightbar (42 amps), 3 radios (15 amps), radar (5 amps), and a siren (15 amps). I don't know how they didn't have an electrical fire.
I upgraded the alternator and wiring, forsaking authenticity for safety and reliability. Anybody planning high current draw mods to their fox body should do the upgrade too. It's too easy and (relatively) inexpensive not to do it.
bloopbloob
578
Alberta
Mar 12, 2008
  • Mar 12, 2008
i'm not sure on this, but IIRC, i remember seeing some kind of secondary amplifier (or something weird, some kind of box?) on ssp's to help with all the electronics? i'm sure someone can clarify this...
TRWXXA
190
Mar 13, 2008
  • Mar 13, 2008
I have no idea what that could have been. You amplify power (watts), not current (amps).
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
