Alternator Upgrading
  • Thread starter Thread starter Mr44666
  • Start date Start date Jan 13, 2004
M
Mr44666
302
Las Vegas, NV
Jan 13, 2004
  • Jan 13, 2004
Hello-
I have been considering using a kit to upgrade my alternator instead of retrofitting. My question is Would I be able to run a larger gauge charge wire alongside the stock, or should the old one be taken out? Also, What of fuse protection and will the external voltage regulator be able to handle the increased output?
Thanks.
-David
M
Mr44666
302
Las Vegas, NV
Jan 13, 2004
  • Jan 13, 2004
Also, Does anyone know what would be involved in Converting to a large case 100amp alt.?
-Dave
T
tweet66
589
Pennsauken, NJ
Jan 13, 2004
  • Jan 13, 2004
Dave,
I converted to a large case in my 66 coupe. I used the 100amp alt out of a Lincoln Continental, 1977 or so, and it was pretty much a bolt in. The harness hooks up the same. The only thing I had to do was "clock" the case so the terminal were in the same position as the original. Benn like that for 2 years now without a problem.
Ken
SandSprite
332
L.A., CA
Jan 13, 2004
  • Jan 13, 2004
tweet66 said:
Dave,
Ken
Did you get the bracket off the lincoln also? I want to do this mod, but haven't found out what to do for brackets.
fitzm65
197
Central Florida (UCF)
Jan 13, 2004
  • Jan 13, 2004
What of the pulley. is this the same or did you swap it so that it would line up?
9
92GT5ohred
53
Atco, NJ USA
Jan 13, 2004
  • Jan 13, 2004
Take a look at pa, they make a kit for that. www.pa-performance.com
G
GaPonyFarm
663
Columbus, GA
Jan 13, 2004
  • Jan 13, 2004
Mr44666 said:
Hello-
Thanks.
-David
I didn't see what year you're talking about... I changed my '66 over to a Powermaster 140 amp alternator with a single wire hookup. It works great and I was able to remove the voltage regulator and all its associated wiring. The charge wire comes with it, as does 2 different pulleys. You can also use your current pulley. I believe it was $249.00 at Mustangs Unlimited.
Hope this helps.
M
Mr44666
302
Las Vegas, NV
Jan 14, 2004
  • Jan 14, 2004
I'm not really interested in doing a swap anymore as I'd like to use all of the stock wiring with in conjunction with a larger charging wire. there are upgrade kits for the stock alternator up to around 105 AMP from alternatorparts.com I think it is. The other option is to use the large case alternator that was optional on most fords from the late 70's to the early 80's I believe.
I don't really trust the one wire conversion alternators as they are activated by RPM and not a voltage sensing wire.
thanks
-Dave
T
tweet66
589
Pennsauken, NJ
Jan 14, 2004
  • Jan 14, 2004
Brackets
SandSprite
I used the originall brackets that were on the car holding the smaller altenator.
fitzm65
As far as pullies, same deal, just swapped the original duoble groove pully onto the Lincoln alt.
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
P
Electrical 2001 GT Overcharging
  • PseudoGT
  • Dec 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 13, 2025
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
