alternator wiring harness
the previous owner of my car decided it would be a good idea to glue the alternator wiring harness to the alternator. so now that my alternator is broke i need to go to the junk yard and pick up a new harness. i was wondering if the 4 cyl. and 8 cyl. had the same wiring harnesses?
thank you
FWIW, for your 95, you can buy a new regulator plug and solder the wires up. They tend to vulcanize, so new is nice.
I have the feeling that the V6 alternator is the same as the GT (ergo the wiring is the same) but someone will know for sure.
Good luck.
You can still buy new plugs for it. Check local parts stores and if not, resto shops like LRS.
Might we assume you're going with a 3G? If so, you should only need the regulator plug.
Good luck.
