Alternators
  • Thread starter Thread starter afterglow
  • Start date Start date Aug 1, 2009
A
afterglow
89
  • Aug 1, 2009
My mechanic says I may need to buy a new alternator. I'm based in the Philippines so I'll need to import one from the US. I have a 69 Mach 1 w/ 351W/C6, power steering and A/C.
What's out there?? What should I get?? Where should I get it??
hhead
280
so cal
Aug 1, 2009
  • Aug 1, 2009
I read your other post. Maybe should try to keep post together.
To the problem. Your alt is showing a charge when you rev it. At idle with the A/C on it drops to about 11v. I think your alt is working fine.
I would check your voltage regulator. Even if it's been replaced before!
Believe me when I say, replace it even if it has been replaced already.
Edit: I like to use the later regulator for my 67. part: C8TF-10316-A its rated for 55A It's a relay type. Large housing. Quit using the full electronic ones, after a brand new one, gave up after two months. Scratched my head on that one for over two weeks.
2+2GT
3,333
10
79
Southeastern Pennsylvania
Aug 1, 2009
  • Aug 1, 2009
Did you not get my PM?
A
afterglow
89
  • Aug 1, 2009
hhead: yeah I was debating whether to use my old post or start a new one. It seems the consensus is that the alt is good. It's already internally regulated so I'll be going with a smaller pulley and see what good that does.
2+2: I only checked in now and I got your message. Thanks for the link. I have a freight forwarder in the US and they have GREAT rates so I'm not limited to vendors that can ship overseas.
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
N
1969 15x10 295's for rear. Modifications needed?
  • normg
  • May 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- May 2, 2026
GypsyR
G
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
