Alum intake ?
  • Thread starter Thread starter 6Stang7
  • Start date Start date Feb 21, 2004
6Stang7
1,470
Livermore, CA
Feb 21, 2004
  • Feb 21, 2004
After the first warm up, do you re-torque the intake when it's hot, or wait til it fully coolest off? Do you ever re-torque it after that?
-Shaun
D
D.Hearne
11,730
south louisiana
Feb 21, 2004
  • Feb 21, 2004
I repeat the torque sequence 4-5 times before running it at all, then never afterwards. Never had one leak.
HistoricMustang
2,359
Confederate States of America
Feb 21, 2004
  • Feb 21, 2004
Yes, torque it 3 to 4 times when installed using suggested sequence (starting in the middle and moving out) before running the engine. If I remember correctly the torque spec is around 23 foot pounds. Start with 10 pounds through the entire sequence, then jump to 15 pounds, then to 20 pounds, etc.
Use a SMALL torque wrench if possible as it will give you a better reading. I go back after the motor is run a few times and do a final check.
It is so easy to over torque intake, heads, carbs, etc and that is where most people get into trouble.
Good Luck,
HistoricMustang
www.historicmustang.com
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
There’s nothing sexier than a woman driving a Mustang!
  • MKatzenbach
  • Mar 20, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk May 2, 2026
