aluminum driveshaft
taylor4g63
921
Asheboro, NC
I remember reading somewhre about you can get an alum. driveshaft out of a ford aerostar van and shorten it, and it will work in a classic stang?? Anybody know if theres any truth to this or any details about it??
use a 2wd aerostar shaft and have it shortened to length, it may not need it so check it carefully, the only i thing i don't know for sure about is the u-joints, bur there should be u joints that will fit without any problems
If it turns out to be true that would be great. If it needed to be cut what would that cost? Can't cut that with a cutting disc on your grinder. Or a chopsaw. Need good tool for that.
I run a '89-91 Ford Aerostar. Paid $20 for it at the JY. It cost me $100 to have it shortened/balanced and $30 for new Spicier joints.
BTW: Starting in '91, they have correct yoke to fit T-5/Toploader.
Don't understand why more people aren't using them.
This has been posted before. From my research, you can use an aerostar aluminum driveshaft, but you will have to have it shortened, welded, and balanced. It should be done for under $150...that will include the original price of the driveshaft.
