Am i going backwards?
  • Thread starter Thread starter bigjim240z
  • Start date Start date Aug 7, 2005
bigjim240z
9
  • Aug 7, 2005
I own and 86 mustang 5.0. Im considering removing the efi for a edelbrock rpm intake, 650 holley double pumper and a b303 cam. I also plan to do a set of tfs heads within the next couple of months. I live in nevada and smog isnt an issue. What will i have to do about the fuel pump? Would a fuel pressure regulator and the stock pump work, or will i have to disconnect the stock pump and add a low pressure eletric pump? Any pointers are appreciated.
jim
M
Mysterio
101
Lakewood, Ohio
Aug 7, 2005
  • Aug 7, 2005
My 93 is converted to carburetor... A regulator will lower the fuel pressure to what you need it to be. Pretty sure you can use the stock pump but it's better off upgrading. Not 100% sure.
Greenracing
109
Puerto Rico
Aug 7, 2005
  • Aug 7, 2005
Yoy have to change the pump or get a Aeromotive Pressure Regulator, very expensive IMHO, so it's better to swith to a Carb
fuel pump.
P.S.
if you are planing to go w the Perf RPM, you should check the Perf RPM AirGap, is a Nice intake.
Scorcher2005
883
South Carolina
Aug 7, 2005
  • Aug 7, 2005
new pump AND fuel pressure regulator are recommended.
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
  • dan50
  • Jul 18, 2026
dan50
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
