what kind of amp is it? i just sent back a blown to bits mtx 4405 (5 channel) to mtx directly and they charge 95.00 to completley rebuild it with a warranty. good luck
i'm not 100% sure but i don't think that the magnet from a sub(s) would do any harm to an amp. how close are the 2?? and what happened..any blown fuses??
The two subs and amp are built into a custom enclosure in the trunk of the Mustang. Maybe it is overheating ? Will try relocating the amp where it can run cooler and see if this helps ! Thanks.
It's definately a heating problem is the amp is running fine and then just shuts down. It's a thermal protect. Add some vents to the cusom enclosure with a fan or two...
