This is for a hardcore drag setup. Light car with a 347 and a manual tranny.
Front:
GMS Tubular K-member (moves wheels forward and engine back)
GMS Tubular A-arms
GMS Coil-Over with 12" 175-200lbs springs. (drag kit)
Lakewood 90/10 Struts
QA1 C/C plates
UPR bumpsteer kit
Weld Draglite 15x3.5" with 165R15 cheapo tires
No swaybar
Rear
HPM Megabite Jr. LCA's
HPM Megabite double adjustable UCA's
Moroso Drag springs
Lakewood 50/50's
Stock swaybar
Weld Draglite 15x8" with 26x10.50R15 M/T ET Streets
I have not tested this combo but I feel it will need more.
Here is what I am thinking of changing:
Swapping the front 12" 175-200lbs springs for 14" 110-130lbs springs. They are just a little firm and dont' have much travel.
Swapping the rear spring out for stock springs because the Moroso's make my car sit way high in the rear, about 3-4" of gap between the wheel and wheelwell. To level the chassis I will need to raise the front way high also, which would be way high, interfearing with the suspension geometery. However the stock springs arn't stiffer on the right side, so it will dip stage right which is never good. Maby an airbag, or probally a roll bar would be better.
Swapping the 26" ET Streets for 28" ET Drags, and keeping a set of Drag radials for street use. This will kill my gear ratio, so then I would need to change the gear as well. I will most likley use the ET Streets up.
How do you think the car would launch as is, and how do you think these changes, or just one of them, or your suggestions would help?
Front:
GMS Tubular A-arms
QA1 C/C plates
UPR bumpsteer kit
No swaybar
Rear
Moroso Drag springs
Lakewood 50/50's
Stock swaybar
