Annoying Misfire Help
  • Thread starter Thread starter gg302
  • Start date Start date Sep 19, 2014
gg302
11
  • Sep 19, 2014
Just bought a 1989 GT and it runs great except for this little misfire. At idle it's normally around 800 rpm and drops to 450-500 rpm's when it misfires. Driving at 1000 rpm's or below causes it to misfire as well. It does not occur at higher rpm's and does not do this every time I drive it. I have changed the plugs, wires, and cleaned the IAC. Has anyone had a similar problem?
Video of car at idle: View: https://www.youtube.com/watch?v=fXI6os9_DUo
J
jka
5 Year Member
Jan 17, 2010
339
23
29
Sep 20, 2014
  • Sep 20, 2014
It sounds like a exhaust leak or a burned spark plug wire could be causing the misfire.. Have you checked the wires? plus have you check for an exhaust leak?..because it sounds like you have one. Both would cause that sound and a misfire.
90lxwhite
I'm kind of a She-Man
5 Year Member
Aug 25, 2011
3,310
374
134
Between the Red and Rio
Sep 20, 2014
  • Sep 20, 2014
Plug boots snug?
gg302
11
  • Sep 20, 2014
Yeah I changed out the plugs and wires a few days ago and it still misfires. It could be the exhaust, it basically cuts off after the h-pipe
Micheal Nadeau
258
32
49
Savannah, GA
Sep 20, 2014
  • Sep 20, 2014
Do you, by chance, have a vacuum leak? Does temperature play any effect on it?
gg302
11
  • Sep 20, 2014
No it doesn't sound like it has a vacuum leak. It happens more when it warms up fully
Micheal Nadeau
258
32
49
Savannah, GA
Sep 20, 2014
  • Sep 20, 2014
Can you monitor fuel pressure while it is happening? I would suspect a fuel delivery issue. You addressed the plugs and wires, did you replace the cap and rotor button as well? Another possibility could be cylinders loading up? Run it cold and its fine. You then get it up to temp and shut it off, go back a few minutes later and restart it and it runs like crap. Injector leaking down? Inspect the old plugs and let us know what the ends looked like.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 20, 2014
  • Sep 20, 2014
Cylinder balance test: use this to find dead or weak cylinders:
Revised 25 March 2012 to add necessity allowing the KOEO tests to finish before starting the engine and the need for a properly functioning IAB/IAC to run the cylinder balance test.
The computer has a cylinder balance test that helps locate cylinders with low power output. You’ll need to dump the codes out of the computer and make sure that you have the A/C off, clutch depressed to the floor and the transmission in neutral. Fail to do this and you can’t do the engine running dump codes test that allows you to do the cylinder balance test.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C clutch depressed to the floor, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Here's how to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems. This is crucial: the same wire that provides the ground to dump the codes provides signal ground for the TPS, EGR, ACT and Map/Baro sensors. If it fails, you will have poor performance, economy and drivability problems
Some codes have different answers if the engine is running from the answers that it has when the engine isn't running. It helps a lot to know if you had the engine running when you ran the test.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off, clutch depressed to the floor and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
If you have idle or IAC/IAB problems and the engine will not idle on its own without mechanically adjusting the base idle speed above 625-750 RPM, this test will fail with random cylinders pointed out every time it runs. The IAC/IAB must be capable of controlling the engine speed to run in the 1400-1600 RPM range. Playing with the base idle speed by adjusting it upwards will not work, the computer has to be able to control the engine speed using the IAC/IAB.
Warm the car's engine up to normal operating temperature. Use a jumper wire or paper clip to put the computer into test mode. Let it finish the Key On Engine Off (KOEO) code dump. Start the engine and let it go through the normal diagnostic tests, then quickly press the throttle to the floor. Remember to keep the clutch pedal (5 speed) depressed to the floor during the test. The engine RPM should exceed 2500 RPM's for a brief second. The engine RPM's will increase to about 1450-1600 RPM and hold steady. The engine will shut off power to each injector, one at a time. When it has sequenced through all 8 injectors, it will flash 9 for everything OK, or the number of the failing cylinder such as 2 for cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause the test to re-run with smaller qualifying figures.
Do it a third time, and if the same cylinder shows up, the cylinder is weak and isn’t putting out power like it should. See the Chilton’s Shop manual for the complete test procedure
Do a compression test on all the cylinders.
Take special note of any cylinder that shows up as weak in the cylinder balance test. Low compression on one of these cylinders rules out the injectors as being the most likely cause of the problem. Look at cylinders that fail the cylinder balance test but have good compression. These cylinders either have a bad injector, bad spark plug or spark plug wire. Move the wire and then the spark plug to another cylinder and run the cylinder balance test again. If it follows the moved wire or spark plug, you have found the problem. If the same cylinder fails the test again, the injector is bad. If different cylinders fail the cylinder balance test, you have ignition problems or wiring problems in the 10 pin black & white electrical connectors located by the EGR.
How to do a compression test:
Only use a compression tester with a screw in adapter for the spark plug hole. The other type leaks too much to get an accurate reading. Your local auto parts store may have a compression tester to rent/loan. If you do mechanic work on your own car on a regular basis, it would be a good tool to add to your collection.
With the engine warmed up, remove all spark plugs and prop the throttle wide open with a plastic screwdriver handle between the throttle butterfly and the throttle housing. Crank the engine until it the gage reading stops increasing. On a cold engine, it will be hard to tell what's good & what's not. Some of the recent posts have numbers ranging from 140-170 PSI. If the compression is low, squirt some oil in the cylinder and do it again – if it comes up, the rings are worn. There should be no more than 10% difference between cylinders. Use a blow down leak test (puts compressed air inside cylinders) on cylinders that have more than 10% difference.
I generally use a big screwdriver handle stuck in the TB between the butterfly and the TB to prop the throttle open. The plastic is soft enough that it won't damage anything and won't get sucked down the intake either.
A battery charger (not the trickle type) is a good thing to have if you haven't driven the car lately or if you have any doubts about the battery's health. Connect it up while you are cranking the engine and it will help keep the starter cranking at a consistent speed from the first cylinder tested to the last cylinder.
See the link to my site for details on how to build your own blow down type compression tester.
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Sep 20, 2014
  • Sep 20, 2014
could be the TFI going, if it only happens when it is warmed up.
gg302
11
#10
  • Oct 1, 2014
  • #10
I've replaced the battery, ignition coil, idle air control valve, MAF, air intake, adjusted the TPS, and the RPM's still fluctuate and it misfires at idle. The problem only happens when the engine warms up. In the mornings it starts and drives fine with no problems. However in the afternoon and after it warms up, it idles and operates very poorly at low RPM's. Today I noticed a ticking sound coming from the new IAC, which is in the video. The only engine code was a 33 for the EGR. Any advice is appreciated
View: https://www.youtube.com/watch?v=35QVZJ6rb7s&feature=youtu.be
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 2, 2014
#11
  • Oct 2, 2014
  • #11
What did you get for the cylinder balance test??
Micheal Nadeau
258
32
49
Savannah, GA
Oct 2, 2014
#12
  • Oct 2, 2014
  • #12
You 100% sure that is coming from your IAC?
gg302
11
#13
  • Oct 2, 2014
  • #13
Not 100%, but it seemed like that area was where the noise was coming from
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Oct 3, 2014
#14
  • Oct 3, 2014
  • #14
As to adjusting the tps ours are non adjustable. Its either in range or its not and is bad is to my understanding.
93 LX 5.0 - 2,000 rpm misfiring, stuttering, and bogging upon acceleration (videos)
  • dan50
  • Nov 14, 2026
Fox 5.0 Mustang Tech Nov 15, 2026
General karthief
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
T
Greetings from a guy who needs help with a foxbody.
  • thefonztm
  • Mar 21, 2026
  • The Welcome Wagon
The Welcome Wagon Mar 22, 2026
A
95 Gt intermittent backfire
  • A_A_Ron
  • May 26, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 26, 2025
A_A_Ron
A
