Considering I started with a stock GT Stang
I had nothing but the lowest performing heads, intake, etc when starting
to mod my Stang
I knew I wanted to go NA
and
The application would be using the OEM block for a Street Combo
I saw two main options
1) OEM stuff
2) After market stuff
I had seen the after market stuff out performed the OEM stuff
but
I also saw the gain was usually not more than around 8 to 12%
and
The cost to obtain that last % of power was not the best value around :Word:
I did #1 to start out with self ported E7 heads/intake but bailed out early
as I knew I would want more.
I then went with #2 and things have worked out much
better than I expected
I have since thought about a blower and will do a KB some day
Now after doing all that
and
If I started out all over again from scratch as I did before with the
same OEM block and Street Car application
I'd do the NA combo with ..........
after market parts from the start and totally skip any OEM stuff
however
If I was gonna do a blower ........
I'd do OEM stuff like gt40 heads/intake with the blower
The OEM stuff will make enough power to split the OEM block
Why put expensive after market parts or put a bunch of money
in machine work to stroke the OEM block when .......
As said above ... the less expensive OEM stuff will make big power
with the added air flow from the blower
To me ... It just seems like throwing good money after bad
If you are stock
and
If you KNOW you are gonna go blown
Get the most power for the least amount of dollar spent and you
still will make way more power than the typical NA Street Combo :Word:
Grady
