Another brake issue!
  • Thread starter Thread starter bdepedro
  • Start date Start date May 27, 2007
bdepedro
362
Outer Banks, NC
May 27, 2007
  • May 27, 2007
My brake lights recently went out on my '70 fastback. They do not appear to connected to any fuses and the tail lights and blinker lights work fine. The hazard lights work in the front but not the rear. From what I can see there should be no other culprit than the switch on the pedal. Does this sound right?
What is the best way to test the switch before removing it?
bdepedro
362
Outer Banks, NC
May 28, 2007
  • May 28, 2007
Anybody familiar with this?
J
jmlay71
20+ Year Stangneter
Jul 16, 2003
67
May 28, 2007
  • May 28, 2007
In case you do not have them:
http://midlife66.com/wiring/wiring.html
Looking at the diagram this circuit goes thru the headlight switch, brake light switch & turn signal switch.
Mike
bdepedro
362
Outer Banks, NC
May 28, 2007
  • May 28, 2007
That's how it looks to me as well and since my headlights and turn signals are working I'm assuming the trouble is with the brake light switch. I'm sure it's cheap enough to replace as a first guess. Thanks.
bnickel
5,640
lubbock, texas
May 28, 2007
  • May 28, 2007
generally when a brake light switch goes bad the brake lights stay on all the time, at least that has been my experience with them anyway. only once have i had them not come one at all and the turn signal switch was the culprit. still though a $5 brake light switch is the cheaper alternative and it certainly won't hurt anything to replace it.
bdepedro
362
Outer Banks, NC
May 28, 2007
  • May 28, 2007
Yeah, I figure I'll start there and if that doesn't solve the problem then I'll replace the turn signal switch as well. That has been on the list anyway since the right turn signal won't cancel and the left won't stay on. I replaced the headlight switch this past year so I'm going under the assumption that that is fine but again, these switches are generally inexpensive.
C
Another lighting issue
  • ChrisCruz1972
  • Jul 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 14, 2025
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
Electrical Foxbody Dash & Hazard lights not working
  • sjmcr
  • Jun 30, 2025
Fox 5.0 Mustang Tech Jul 27, 2025
Mindseye007
