  • SN95 4.6L Mustang Tech
Another Cooling Problem
  • Thread starter Thread starter Malevolyn
  • Start date Start date Jun 10, 2006
Malevolyn
18
Lakeland, FL
Jun 10, 2006
  • Jun 10, 2006
This is what happens: When I first start driving the car, it heats up normally. After a little while (about 2 miles), the temp climbs way up, up into the A and L area, but so far the car hasn't gotten out of normal. But after a while of driving, it'll drop back down into the R and M area. Sometimes it goes back up under acceleration (any accel, period) but will drop back down while cruising.
I've got a leak somewhere, I'm fairly sure, but I haven't pressure checked, yet, so I'll do that first. But does anyone know anything specific that could cause a weird cooling problem like that? Time of day doesn't change much, either. It's only slightly cooler when driving at night than it is driving in the afternoon. Not even a half-letter difference but enough to be noticeable.
Also, anyone know an easy way to get this damn upper radiator hose off?
sgarlic
3,085
Jun 10, 2006
  • Jun 10, 2006
Sounds to me like you've got some air in the system. Have you tried burping it?
My second thought was maybe your temperature sensor is bad.. the way I read your description is that the needle sort of bounces around between the higher and middle ranges.. if it's doing it quickly, I still vote air in system, or temp sensor.
Malevolyn
18
Lakeland, FL
Jun 10, 2006
  • Jun 10, 2006
Yeah, my dad said I should bleed it after i flush/seal it. I'm pretty sure the temp sensor is good. I've never bled a cooling system before, how would I go about doing it?
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jun 10, 2006
  • Jun 10, 2006
you have to bleed your cooling system.. best way to do it without a vacumm bleeder is to run the heat on high out the dash vents ( just so you can feel if you have steady heat) and bring the rpm's up a little 1200-1500 is good.. and then add coolant as needed... If you do this with the cap off the cooling system you will have some coolant flow out of the bottle.. don't worry this is normal.. if you do this with the cap on be very very carefull not to burn yourself.
Malevolyn
18
Lakeland, FL
Jun 11, 2006
  • Jun 11, 2006
Hmm, but I don't have a compressor, so that way is pretty much out. I think I have it worked out, though, because I was putting in some flush, ran the car until it heated up, squeezes the upper hose a few times and suddenly the contents of the overflow bottle was sucked into the radiator.
Mike97gt
it doe snot
10,633
Jun 11, 2006
  • Jun 11, 2006
there you go sounds like you are getting some of the air.. be carefull removing the cap when it's hot... I turn it a tiny bit let the presure relase then slowly open it.
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
