another delema
LT1 Eatr
20
i did my mass air conversionand it seemed to work just fine for about 2 minutes. first of all i bought the car from a dude that had no idea of the mods on it. the car was in rough shape. the exhaust was non exsistant much like the clutch. it idled irratically but i thought the exhaust had something to with it but it just made it quiet. so i did the maf conversion. it has gone away some butnow it cuts out when i come to a stop. it either stalls or i save it by a stomp on the go petal. after i give it a stomp it will smooth out but if its a long red light it will slowly start to lope. i do know that since the maf conversion it sounds like it has a hefty cam. i just don't know where to turn. also when i'm gettin it full throttle this thing is raped. i had a 95 cobra and this thing is faster. somebody through me a bone i just want it a little less embarassing when i stop at a light. i was wondering if it could be fuel pressure, aic motor,tps, or any simple fix:bang:
clean the IAC valve(first thing I would do, carb cleaner works wonders!), mine studders on cold, cold starts and my FPR is bad, I have the new one, just going to put it in when my car is down for the build, the tps voltage should be at .99 i believe.
well 1st how do i clean the injectors?i did use the lucas tune up in a bottle but what other way is there? 2nd what is a FPR?. i will clean the iac tomorrow but i was told cleaning it is hit or miss. it is worth a try though.
FPR= Fuel Pressure Regulator. When your idle is jumping around, hook up a fuel pressure guage to the fuel rail and see what it is, it should be a constant 35-43, if it dips or jumps around it is probably an bad FPR
sounds like a vacum leak to me... just start following vac lines. check the ones that connect to the underside of the intake plenum, those could definetly be it. however, there is a "surging idle checklist" thread around here, maybe ask one of the mods to get it for you. (or just find it).
good luck man, oh, and try post5ng th5s 5n tech t66 (sorry, damn number lock)
i can't spell cause i'm a body man not a english teacher.lol
as far as when it surges it does it hot or cold. doesn't mater which. i have a adjustable fpr but its not on cause i can't seem to get to the one allen screw to remove and install the new one. any tricks to that? also i didn't know where to set it. what is the optimum fuel pressure for this car? just one more thing is when i bought the computer (a9p) for the maf swap , it came with a asc super chip. whould this possibly help my "dilemna" and yes i looked so i knew how to spell it.lol
if you want me to take some pics, I plan on changing the FPR tomorrow after school. I should post some pics around 4pm tomorrow, and I don't know half as muchas alot of these guys, just a teen trying to learn form the greatest stangnet has to offer!
me too. i've been on primedia's mailing list but you never learn better than from someone whos done it. if you could take the pics that would be great. you can email them to me at pacarguy04@hotmail. or at least mail me the link to you pics. thanks
