another fuel pressure question
  • Thread starter Thread starter dw89lx
  • Start date Start date Jul 15, 2005
dw89lx
44
Boston, MA
Jul 15, 2005
  • Jul 15, 2005
I 've noticed that if I let my car sit overnight or at work the fuel pressure drops really low, like 10 to 20 psi. Is this normal or do I have a problem? I usually have a hard time keeping the car idling in the morning until it gets warmed up and thought that this could possibly be part of my problem.
HISSIN50
34
129
Jul 15, 2005
  • Jul 15, 2005
How is pressure when it idles poorly?
It can be quite normal for pressure to bleed off over time, esp with aftermarket FPR's. But once you are running, you should not see below 30 PSI.
Do you have to prime the pump more than once to get the car to start (or does it require extended cranking to catch?)?
Good luck.
dw89lx
44
Boston, MA
Jul 15, 2005
  • Jul 15, 2005
The pressure is set to 42psi and it stays there as long as the engine is running even when it's idling poorly. It only drops with the engine is off for a few hours.
I just wanted to make sure that it was normal.
HISSIN50
34
129
Jul 15, 2005
  • Jul 15, 2005
Yeah, totally normal IMHO. The poor idle is a separate issue. It sounds like you have mods since you have the FP set higher than stock. If wanting opinions on what to try (other than cleaning the IAC) with the idle issues, post sig info.
Good luck bud.
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
