ANOTHER FUEL PRESSURE QUESTION
  • Thread starter Thread starter KENS89LX
  • Start date Start date Jun 27, 2007
KENS89LX
302
Cross lanes Wv
Jun 27, 2007
  • Jun 27, 2007
i JUST INSTALLED A ADJUSTABLE FUEL REGULATOR ON MY 89 AND AM WONDERING ABOUT THE PRESSURE VERSUS VOLUME, IF THE PRESSURE IS HIGHER SAY 41 LBS IS THAT MORE OR LESS FUEL THAN 38LB?
ShortThrow50
923
Pa
Jun 27, 2007
  • Jun 27, 2007
WHEN YOU HAVE MORE PRESSURE, YOU HAVE MORE FUEL. yOUR ALSO LIMITED TO WHAT THE INJECTORS SPEW OUT AND HOW MUCH FROM WHAT THE COMPUTER TELLS IT. can you hear me now? lol
KENS89LX
302
Cross lanes Wv
Jun 27, 2007
  • Jun 27, 2007
ok so how much pressure would 19lb inj stand? and what is the stock regulators pressure?
ShortThrow50
923
Pa
Jun 27, 2007
  • Jun 27, 2007
around 38 psi i beleive, with the vaccum line disconnected. how much can the stockers stand? As much psi as you throw at it but its only gonna put out what its rated at. I dunno. Im not positive though.
jtfairlane
468
  • Jun 27, 2007
WRONG.
The higher the fuel pressure, the less the volume.
A 190lph fuel pump is equivalent to 50gal/hr. Here is an example pump flow rate for a 190lph fuel pump with flow in gal/hr. As you can see, the pressure to volume is an inverse relationship.
Fuel Pressure (psi) gal/hr
0 56
10 52
20 48
30 44
40 40
50 36
60 32
70 28
80 22
90 12
ShortThrow50
923
Pa
Jun 27, 2007
  • Jun 27, 2007
jtfairlane said:
WRONG.
0 56
10 52
20 48
30 44
40 40
50 36
60 32
70 28
80 22
90 12
What subject are you talkin about? Where talking fuel pressure and fuel injectors and your talkin pumps. Do u set ur fuel pressure lower at your fpr and the gauge mounted on your rail expecting more fuel pressure at your injectors? For u engines sake, i hope not
vristang
4,933
101
124
Seattle
Jun 27, 2007
  • Jun 27, 2007
jtfairlane said:
WRONG.
0 56
10 52
20 48
30 44
40 40
50 36
60 32
70 28
80 22
90 12
I'm not really sure what you are getting at here, but I don't think this is the question the original poster was trying to ask...
When you increase the fuel pressure in the rail, then more fuel is going to flow for the same injector pulsewidth.
In other words...
More PSI = More Volume Flow
Again, I'm not sure what your getting at with the pump comments...
Maybe you can elaborate?
jason
ShortThrow50
923
Pa
Jun 27, 2007
  • Jun 27, 2007
In other words...
jason
thats what i was getting at, but I guess the obvious isnt so obvious anymore. Apparently more fuel pressure on the line = less fuel flow through the injectors. I hope this guys engine doesnt lean out.
vristang
4,933
101
124
Seattle
Jun 27, 2007
  • Jun 27, 2007
Here is the answer to the question you were trying to ask...
Your pressure should be set pretty close to the factory level; 38-41psi, depending on what book you look up the spec. in.
The answer to the question you did ask...
The stock system *should* be able to handle up to 50psi (or up to 60psi if you believe some sources), with out any metering issues from the injectors.
By the way... If the fuel pressure has to be set this high (over ~45psi), then there is a deficiency in the system somewhere.
For the most part stock pressure is the "BEST" pressure setting. Moving away from the stock pressure can cause ecu issues.
My rambling thoughts,
jason
vristang
4,933
101
124
Seattle
Jun 27, 2007
#10
  • Jun 27, 2007
  • #10
0 56
10 52
20 48
30 44
40 40
50 36
60 32
70 28
80 22
90 12
I get it...
You are talking about the relationship between pressure and volume in a sealed system...
PV=nRT (IIRC)
This is different from the effects of pressure on Volume Flow...
jason
jtfairlane
468
#11
  • Jun 27, 2007
  • #11
This is one of those....
"my bad" situations....
I skimmed through the original question and didn't read it through.
Sorry, I take it back!
This time....
vristang
4,933
101
124
Seattle
Jun 27, 2007
#12
  • Jun 27, 2007
  • #12
This time....
lol
We've all done it
KENS89LX
302
Cross lanes Wv
Jun 29, 2007
#13
  • Jun 29, 2007
  • #13
Thanks guys...I think, but now the guage is'nt working ..do you know how far the guage needs to be screwed on to the line.. I have maybe another half turn but no pressure reading so far
ShortThrow50
923
Pa
Jun 30, 2007
#14
  • Jun 30, 2007
  • #14
I just kept screwing mine down to where it was getting pretty tight. If your sure its not down tight enough, give her another turn , enough so you can read the gauge
enyawix
507
Apr 3, 2008
#15
  • Apr 3, 2008
  • #15
vristang said:
I get it...
PV=nRT (IIRC)
jason
what pressure would do damage to the injectors?
Fuel 1990 installing edelBrock intake
  • Beaker
  • Oct 5, 2026
Fox 5.0 Mustang Tech Oct 6, 2026
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
J
Having fuel issues
  • Jbands2v
  • Nov 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 2, 2026
LILCBRA
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
